EF suspension on ITR?
Old Apr 10, 2006 | 07:20 PM
Petah's Avatar
Default EF suspension on ITR?
Does anyone knows if it will fit? Looking from pics, they look like it's the same part as the EG/DC units. Thanks.
Old Apr 10, 2006 | 07:45 PM
Crx Jimmy's Avatar
Default Re: EF suspension on ITR? (Petah)
they will fit I believe but the caster will be off, the spindle is shaped slightly different
Old Apr 11, 2006 | 02:10 AM
Petah's Avatar
Default Re: EF suspension on ITR? (Crx Jimmy)
Sorry, i should of been more specific. My question is for shock/spring coilover assembly. Say a set of BC racing spec, will they work for a ITR?
Old Apr 11, 2006 | 06:45 AM
eg6ajk's Avatar
if its JDM then rear works without any issues. front works as well only problem you 'll run into is that struts are much shorter on the EF (fronts) otherwise use you're old forks and rear LCAs and you're good to go. Make sure you have enough of spring rate!
Old Apr 11, 2006 | 06:58 AM
Petah's Avatar
Default Re: EF suspension on ITR? (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk &raquo;</TD></TR><TR><TD CLASS="quote">if its JDM then rear works without any issues. front works as well only problem you 'll run into is that struts are much shorter on the EF (fronts) otherwise use you're old forks and rear LCAs and you're good to go. Make sure you have enough of spring rate! </TD></TR></TABLE>
AH HA! Adrian to the rescue! But i would assume if it's something like buddy clubs, OMNIs, etc where you can lengthen/shorten the entire shock, even with the shorter fronts, it should still be ok. Thanks!
Old Apr 11, 2006 | 10:49 AM
Black R's Avatar
25 Year Member
why would you want to do that, though?
Old Apr 11, 2006 | 10:55 AM
Petah's Avatar
Default Re: (Black R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R &raquo;</TD></TR><TR><TD CLASS="quote">why would you want to do that, though? </TD></TR></TABLE>
There is a guy locally who has a set on his EF that he wants to sell for a pretty decent price.
Old Apr 11, 2006 | 10:57 AM
aziantegger10's Avatar
hmm.
Old Apr 11, 2006 | 05:02 PM
Black R's Avatar
25 Year Member
Default Re: (Petah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">There is a guy locally who has a set on his EF that he wants to sell for a pretty decent price. </TD></TR></TABLE>
.....in that case, buy low and sell high, make some $ and get the correct parts for your application.
jdm4drSi
11
Sep 13, 2008 12:07 PM
OC Geezer
Suspension & Brakes
Mar 13, 2008 12:02 PM
RED_90TEG
Dec 20, 2007 12:15 PM
hatchlessrex
Jul 12, 2004 03:06 PM
epren
Aug 5, 2003 04:09 PM
