SOHC ZC dizzy plug not matching Std. harness's dizzy plug!
Just like the title says, the plug on my <U>S</U>OHC ZC's distributor does not match the plug on my Std. Civic's wiring harness. How can i get it to work? all the wiring diagrams are for DOHC ZC's. How do i get my SOHC wired up?!?!
I had that writeup already only one paragraph helped me:
"...For SOHC engines such as the Si
-Connect the C1 wire to the blue/green wire on the CPS (the sensor is inside the Distributor on a SOHC engine). For doing this I suggest swapping out to the proper Si distributor plug so it is all plug and play and looks clean.
-Connect the C2 wire to the blue/yellow wire on the CPS."
That's cool, but where do the other wires go?!
Ya, I get the ECU wiring...
But my male Distributor plug on the engine wiring harness doesn't match the female Distributor plug on the engine! I would like to just cut the plugs off completely and solder the wires directly together, but which wire goes where?
In other words...
I have seven wires at the dizzy plug, two of them i know go to the cyl pos wires.
But, i have five more i need to match to the other five on the engine. How do i know which goes where?
Tippyman
Apr 11, 2006 11:21 AM
phokemon
Oct 31, 2004 06:19 AM
