FS: Built B20/Vtec "BOOST READY" Race ported head 500hp+
Im selling a B20/vtec boost ready Motor. I think it will be good for 400+ whp. lots of work done on this. The head is awsome. ******* sweet. The head was Port an polished for turbo applications. +1mm on the intake an the exhaust. Specs below
B20B Vtec Setup
<U>Bottom End Build:</U>
wiseco pistons 9.1 cr
Scat Rods (Upgraded pins)
Race Engernering Block Gaurd
Cleavite Bearing
High Boost MLS head Gasket
ARP Head Studs
Balanced Crank
<U>PR3 head build</U>
+1mm Stainless Reduced Stem swirl polished valves(I/E)
Type R cams
Titainum Valve springs
Duel spings
Heavy port an polished (Made For turbo app)
<U>Flow Chart:</U>
<U>Other:</U>
New timming Belt
oil pump
water pump
Dizzy is also included with a Mugen Valve cover
No intake manifold or fuel components. Of course the motor will be built when you buy it. Its apart to show the work. All new seals an gaskets...Make an offer.
No low ballers please
Modified by DrivinVtec at 11:14 PM 4/10/2006
B20B Vtec Setup
Cleavite Bearing
ARP Head Studs
Balanced Crank
Type R cams
Duel spings
<U>Flow Chart:</U>
<U>Other:</U>
New timming Belt
oil pump
water pump
hbboostman
Nov 1, 2008 08:43 PM
a1320honda
Aug 6, 2008 01:39 AM
