wiring help
on my 00 si i cant remember what color the wire is for the throttle position sensor on the back of the trottle body for when your putting zex in your car. Little help would be nice
thanks
thanks
Not sure if its the same. but a obd2 integra is yellow/blue. Should be the center wire. Check it with a volt meter. Should be at 5 volts when pedal is down all the way. And 0 volts when pedal is all the way up. It will sweep when you push down the pedal. Check it with the motor off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowrexsi »</TD></TR><TR><TD CLASS="quote">Not sure if its the same. but a obd2 integra is yellow/blue. Should be the center wire. Check it with a volt meter. Should be at 5 volts when pedal is down all the way. And 0 volts when pedal is all the way up. It will sweep when you push down the pedal. Check it with the motor off.</TD></TR></TABLE>
.5 V at closed and 4.5 V at wide open throttle
ReactioN
15
Oct 2, 2011 06:36 PM
CTRwannaB
Dec 6, 2003 04:52 PM
