!!Help!! 91 CRX w/b16a obd0 Bogs out on highway
Old Apr 10, 2006 | 06:07 PM
BlackLudeSi's Avatar
Default !!Help!! 91 CRX w/b16a obd0 Bogs out on highway
EDIT some pics
Just like title says, I just picked up this CRX with a obd0 B16a swap (cable) and when it gets driven on the highway for awhile ( 10-15mins) its starts bogging in 5th if i let off the gas then punch it, accerates fine but if i hold the petal steady it bogs and jerks. Im heading out he the garage to check it out, pop back in a bit, give me some idea's! Don't want it to die completely on highway.
Modified by BlackLudeSi at 9:41 PM 4/10/2006
Old Apr 10, 2006 | 06:11 PM
SimplyTron's Avatar
Does it do it like after you let off the gas and let it slow down for a few seconds then get back on the gas slightly and it doesnt react? Then the farther you push all of sudden its like wham power? This is the same problem Im having with my obd0 B16a. Ive replaced everything so far except injectors and map sensor and TPS sensor Im willing to bet its one of those which I dont know though wait for someone else to chime in.
Old Apr 10, 2006 | 06:15 PM
looxs's Avatar
Default Re: (SimplyTron)
I think i have the same problem as Tron....i was told it was because it's only reading off of 1 O2 sensor and b16's read 2 O2 sensors thats why it boggs out when youre at a constant speed then with a slight throttle addition it jumps. Let me know if you have a solution because when i checked last both my O2 sensors are hooked up so i dont know where to go next.
Old Apr 10, 2006 | 06:41 PM
Thats the exact problem whats up, i don't have any 02's the one in there isn't hooked up but no CEL
Old Apr 10, 2006 | 06:50 PM
SimplyTron's Avatar
Hook it up. Now that I think of it Im not too sure how mine are hooked up Im going to have to double check that.
Old Apr 10, 2006 | 06:53 PM
looxs's Avatar
let me know it it fixes it cuz maybe its the blind tune im running too
Old Apr 10, 2006 | 06:54 PM
Default Re: (looxs)
ill have to try, ill let you guys know tomarrow, the o2 is way under car by shifter, any other ideas if its not 02? Just freaked im going to get stuck.
Old Apr 10, 2006 | 06:59 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (BlackLudeSi)
your o2 sensors should be in the exhaust manifold.
Old Apr 10, 2006 | 07:03 PM
Default Re: (mar778c)
its at the bottom under car, its a DC header, should i get a different one? Is this forsure what is causing this?
Old Apr 10, 2006 | 07:07 PM
HatchBox's Avatar
Skoobie no more...
https://honda-tech.com/zerothread?id=404493&page=2
hth
Old Apr 10, 2006 | 07:15 PM
Default Re: (HatchBox)
Perfect HT come through again! Just checked wires, just has one white wire not going anywhere Thanks alot!!!
would any b16 exhaust mani work or do i need a jdm one?
Old Apr 10, 2006 | 08:02 PM
sauceja's Avatar
What ever OEM exhaust manifold you use you need the downpipe from the same manifold. There are many variations out there from what I have heard.
I have two for sale one with o2 sensors. One without.
texasboy13
Mar 7, 2008 11:00 AM
skUnK2jdm
30
Nov 25, 2007 01:11 PM
PINKS
21
Dec 24, 2006 10:45 PM
