Please look at my compression and leak down results? Checking for bent valves
If you have scene my earlier post https://honda-tech.com/zerothread?id=157927
I was told to do some tests and this is what i found
I did A compression test
Cylinder 1 - 180
Cylinder 2 - 185
Cylinder 3 - 200
Cylinder 4 - 180
After that i did a leak down test and I heard no leaks on the intake or exhaust side.
This is how i did it (please let me know if i did it correctly)
Turned the crank til 1 and 4 topped out
I pumped 40psi into number #1 and nothin out the opened TB or the Exhuast and i did not lose any pressure in the air tank
Same for # 4
Then i turn the crank until 2 and 3 where topped out and did the same thing
with the same results.
Dunno what to do next.
Side note my Spark plugs are black like super rich black
and i can see alot of black deposits on the piston head
I bought new plugs but they gave me the wrong ones i think cuase they like longer
The stock plugs in there are NKG PFR6G
The ones they gave me where NKG PZFR5F-11
I dont think they rae the right ones but if anyone knows exactly let me know
Talks for all replies
Cylinder 1 - 180
Cylinder 2 - 185
Cylinder 3 - 200
Cylinder 4 - 180
Same for # 4
95c1v1cs1
Apr 21, 2005 07:32 PM
