snapped rear lca bolt -- what to do?
Old Apr 10, 2006 | 05:09 PM
thenick's Avatar
Default snapped rear lca bolt -- what to do?
What can I do to remove the bolt? The head straight up snapped off and I'm dying to get some suspension on my car
Old Apr 10, 2006 | 08:05 PM
yellowrexsi's Avatar
Default Re: snapped rear lca bolt -- what to do? (thenick)
Use a press to take out the bushing and buy a new one. About the only option.
Old Apr 10, 2006 | 08:20 PM
Deo's Avatar
Deo
I had that happen to me but I was lucky enough to already have the trailing arm off the car. The bolt seized to the inside of the bushing sleeve and was too long to pull out. I ended up cutting through the sleeve and the bolt on the side opposite the head to get the arm off, then taking a blow-torch to the leftover end and using vice-grips to twist it out (hope that made sense...).
It was far from fun, you might be best off taking it somewhere and paying to have it removed. Take a lesson from this and use anti-seize when you put it back togeather.
MrToxygen
Apr 27, 2010 06:11 PM
Circaskaterr
Nov 23, 2009 09:07 PM
sde780
Oct 28, 2009 02:36 AM
teg92
Feb 2, 2004 05:21 PM
B18G
Jan 6, 2004 08:48 PM
