Honda Accord 1994
Old Apr 10, 2006 | 04:42 PM
arvind_h's Avatar
Default Honda Accord 1994
I am planning to change my muffler by mself. A jack and two jack stands is what I intend to use to help me get under the car.
ANY ADVISE IS APPRECIATED.
THANK YOU.
Old Apr 10, 2006 | 05:28 PM
wingback44's Avatar
Default Re: Honda Accord 1994 (arvind_h)
did you search first to see if there was anyone outhere who had the same question but got it answered? P_adams will almost certainly know the answer, so you better hope he finds your thread. only then will you be truley enlightened.
Old Apr 10, 2006 | 05:56 PM
accord-pro's Avatar
you need a can of wd-40.. to lube the rusted nuts and the rubber muffler hangers, get a big screwdriver . sometime thse rubber hangers are hard to remove just by hand .. you need a 14mm socket, extension, rachet, to remove the bolts ( nuts ) that attach the muffler to center pipe. and hopefully you will not need a torch ..to heat up the bolts , for being so rusted .and if the old muffler has chrome tips and you want to reuse them,, you need a 10mm socket as well. to loosen up the bolts and slide the chrome tips pff the old muffler tail pipe
syknxv3
May 17, 2009 09:00 AM
ConanDan
Nov 4, 2007 06:44 PM
xingyun
Jan 15, 2005 07:45 PM
mellenium
Honda Motorcycles
May 29, 2004 02:18 PM
Weston
Apr 25, 2002 08:31 PM
