Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
problems after timing belt change
Old Apr 10, 2006 | 04:00 PM
Mentat Ghola's Avatar
Default problems after timing belt change
i changed the timing belt on my sisters CRV, since then theres been problems. First she said it owuldnt start right away, now it tends to stall when its cold. The best thing i could think of is the crank position sensro. I did mess with it, removed it and reinstalled it, and i disconected hte plug and reconected it. Would this cause the stalling? Does the ECU look at thecrank sensro after sarting? I thought this sensor was only for initial startup and then the dizzy takes over, i oculd be wrong. Does this sound reasonable? Any other sugestions? Would a leaking water puimp cause this? Water acumulating on the botom of the cover while the car sits at night? please help meout, im gonna tear it down again tomorow.
Old Apr 11, 2006 | 12:49 PM
onepoint6i's Avatar
Default Re: problems after timing belt change (Mentat Ghola)
if it was the crank sensor, the mil would come on...
how many miles does it have? recheck the cam timing and make sure its within spec..
Old Apr 11, 2006 | 01:05 PM
GreenD's Avatar
Default Re: problems after timing belt change (onepoint6i)
check the timing marks too. you could be a tooth off at one of them. did you use a new water pump? how does it idle?
Old Apr 12, 2006 | 02:56 PM
Default Re: problems after timing belt change (GreenDestiny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenDestiny &raquo;</TD></TR><TR><TD CLASS="quote">check the timing marks too. you could be a tooth off at one of them. did you use a new water pump? how does it idle?</TD></TR></TABLE>
You know what I did. I was just thinking about this today. If theres an air buble would the IAT or the ICV cause it to stall? It runs perfect when its warm. HEr husband says it runs great, if the timing belt sliped i think hed notice the diference. And it only stalls out when its cold. So im thinking its an idle air problem. This would make more of a diference on an automiatic car (which it is) cause you couldnt gas/clutch it. HOpefuly it just needs a coolant flush. Any thought on this?
I called her husband and told him to check the idle tomorow morning. It shu\ould be at atleast 1200 right? Maybe even 1300-1400? If its below one thousand im flushing the coolant.
Old Apr 13, 2006 | 07:06 AM
onepoint6i's Avatar
bleed the system with a bleeder
Old Apr 13, 2006 | 09:11 AM
Ross 2.0's Avatar
In a Junkyard near you.
ha you quoted me. I forgot I had said that
Old Apr 13, 2006 | 12:19 PM
onepoint6i's Avatar
Default Re: problems after timing belt change (MooGoCow3)
huh?
Old Apr 14, 2006 | 07:44 AM
Ross 2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooGoCow3 &raquo;</TD></TR><TR><TD CLASS="quote">
I have no idea what "vtak" fluid is but the condenser has nothing to do with it.
Vtec fluid is engine oil, and doesn't flow anywhere near the condenser or radiator...</TD></TR></TABLE>
cptmoney
Apr 23, 2014 08:18 AM
TegraD
May 25, 2008 07:59 PM
TorquelessB16
May 24, 2006 12:33 PM
Mentat Ghola
Apr 12, 2006 07:53 AM
Contender25
Jun 9, 2005 07:10 PM
