Cooling fan ? Which ones +?
My car is all apart so i cant start it and test it. Im installing a slim fan and i need it to be a puller so i have to wire it backwards. Does any one know which one is positive on the crx harness?
the blue or black.
Modified by HT Chaplin at 7:12 AM 4/11/2006
the blue or black.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin »</TD></TR><TR><TD CLASS="quote">My car is all apart so i cant start it and test it. Im installing a slim fan and i need it to be a puller so i have to wire it backwards. Does any one know which one is positive?
the blue or black.</TD></TR></TABLE>
usually black is ground, to be sure just twist the connections by hand, tape them up with some electrical tape and turn on the car to make sure. That way you're 100% sure before you make permament connections/solder.
I have the same wiring set-up, blue is positive, and black is negative. Some other aftermarket fans come with red as positive, and black as negative.
donaldmejr
Jul 10, 2010 09:38 PM
