SEAFOAM on 240K F22......... yayh or nahah ???
It can be bad if your engine has a **** load of miles and a **** load of crud in it..because the crud can act as seals - breaking them could cause leaking.
Use at your own risk
found this quote somewhere on here ^^^^
what would u guys recommand to do about seafoam and high K f22 engine ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fear »</TD></TR><TR><TD CLASS="quote">the thing is i just changed plugs a few weeks ago... do i really need to change again </TD></TR></TABLE>
no not really, ive never changed mine, but ive always had new ones after i did it.
if you throw some in the crankcase then you will want to take about a 30 min drive or so and then change the oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-pro »</TD></TR><TR><TD CLASS="quote">see if you can get your hands on the BG PRODUCT 3 STEP, INJECTOR CLEANER KIT..
Where can you find this???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 »</TD></TR><TR><TD CLASS="quote">
Where can you find this???</TD></TR></TABLE>
http://www.bgprod.com/products/fuelair.html
so did anyone try this seafoam on an f22 with over 240Ks i might have alot of carbs in there... should i still use the full bottle 1/3 gas 1/3 oil 1/3 booster or should i use half the bottle and then use the other half some time later ?
I used the seafom thing recently, I can't confirm that it did anything for the car. (maybe smoother idle?, I can't tell because my car idle smooth even before) But there was surely a lot of smoke. I used 2/3 into intake manifold, and the rest into gas tank.
any one use entire bottle through vacuum lines ? i did 2/3 and rest in tank and smoked a lot. heard so many things about different amounts of it in different places i dont know whats the best place to use most of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">that's normal for it to smoke like that whe you put it into the intake.........</TD></TR></TABLE>
yup.
Just do it, it wont do anything but help.
yup.
hookedonvtec
15
Oct 13, 2004 01:12 PM
240, 240k, accord, california, discussions, f22, f22a, honda, intelligent, miles, put, sale, seafoam, southern
