hmm...weird thing...should i try this on my trannies?
Old Apr 10, 2006 | 11:43 AM
rice a roni's Avatar
Default hmm...weird thing...should i try this on my trannies?
the current tranny in my 90 crx hf makes a loud ticking noise when i release the clutch pedal and goes away when i step on the cluth pedal...i searched and it ended up being the input shaft bearing? so i bout a 88 crx hf tranny...stupid me, that i didnt know it wouldnt fit because of the spline count difference so do you guys think that the input shaft bearing in that would fit into my 90 hf? i would just swap the 88 tranny in but i would need a new clutch disc and flywheel and i dont feel like spending that much on a daily driver.
Old Apr 10, 2006 | 12:01 PM
jlicrx's Avatar
Default Re: hmm...weird thing...should i try this on my trannies? (rice a roni)
it will fit - you will need to disassemble both transmissions to change it
Old Apr 10, 2006 | 03:53 PM
YasRex's Avatar
Bearings are the same between years.
The spline counts on the two mainshafts (aka input shafts) transmissions are different. The splines on the shaft interface with your clutch disc. So you have two options. You can take advantage of the old shaft using your old clutch or you can use your new shaft with a new clutch for an 88 hf crx.
Since this just started your existing shaft probably isnt damaged at all so I wouldn't worry too much about being forced to replace it. But the only way to know is crack open your tranny.
I did this last week and I decided to go with the higher spline count shaft and a new 212mm clutch/flywheel for a 92-99 civic for better friction. Theres a post on spline counts do a search.
Also, when you pull your transmission and before you take it apart check your throwout bearing for clicking. That may be the issue. If so you don't have to do all that work for nothing. You can just buy a new clutch kit for $100.00 and that comes with a throwout bearing. Not worth it to buy the bearing by itself you'll pay $30 bucks or more.
Good luck!
Old Apr 10, 2006 | 06:22 PM
Default Re: hmm...weird thing...should i try this on my trannies? (YasRex)
ok thanks guys
Old Apr 10, 2006 | 07:32 PM
Speed--Freak's Avatar
Sell me the guts from the tranny you don't use.
Old Apr 11, 2006 | 10:55 AM
Default Re: (Speed--Freak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed--Freak &raquo;</TD></TR><TR><TD CLASS="quote">Sell me the guts from the tranny you don't use.</TD></TR></TABLE>
they're both hf trannies...still want? you can have for free after im done.
Old Apr 11, 2006 | 01:20 PM
Sure
I just need the 5th gears to put in my 91' Si tranny.
Old Apr 11, 2006 | 01:34 PM
got an si i can buy off of you?
Old Apr 11, 2006 | 06:55 PM
Sure I have one with 58,000 for $7500 and one with 38,000 I paid 9K for but don't know how much I would sell it for.
Take your pick.
Old Apr 12, 2006 | 12:08 AM
YasRex's Avatar
Default Re: (rice a roni)
put me down for an hf 5th cog, email me
Old Apr 12, 2006 | 11:28 AM
Default Re: (YasRex)
i ment just the tranny...lol. not the whole car.
Old Apr 12, 2006 | 06:36 PM
Ooops
No, I'll be keeping the Si tranny.
I just want to put an HF 5th gear in it to drop my rpms about 700 when I'm on the highway.
Old Apr 13, 2006 | 03:54 AM
lol...i know what you mean. i'm going to start working on the trannies maybe today. hey do you guys think maybe i can just switch the main shafts?
Old Apr 14, 2006 | 01:00 PM
Hey, I just noticed you are in Wi.
What city you in?
MPGIan
Apr 4, 2011 08:04 AM
DatatRex
Jan 15, 2009 08:10 PM
Maireeka
Nov 9, 2008 04:27 PM
rice a roni
May 2, 2006 01:40 PM
xmd
Dec 8, 2003 05:37 PM
