New gauges
I installed some greddy gauges today. I was wondering what normal oil temps and pressures are. I am using the s2k filter so I guess mine should be on the high side as far as pressure. I was getting between 6 and 6.8 kg/cm on pressure. The cruising oil temp is ~95 Deg C. After some running into vtec it jumped up to 110 Deg C. These sound like normal?
