howmuch of a difference will this make?
i have a h22 with a p2u5, in my civic, the tranny apparently is from accord. how much time will i cut off the quarter if i swapped in a jdm h22 tranny with lsd (M2B4), hers a link, i dont know how to calculate this
, also could i use the k20 rsx-s tranny?
Accord trannies have extremely long gears, the h22 would help tremendously & LSD is always a plus with getting power to the ground. You could also look into the h2b kits that allow you to use b-series trannies on a h block. Since you already did the work to install an accord tranny in there you might as well just go with the h22 tranny.
No, as far as I know you cannot use a k-series tranny with a h block
F22B1 P2U5 3.307 1.809 1.185 0.933 0.685 - 4.062 USDM
H22A M2B4 3.307 1.950 1.360 1.034 0.787 - 4.266 JDM LSD
it dosent really loko like that much of a difference but then again what do i know.
how much time do you think ill shave with this.
does it really matter as long as im in vtec>?
also does anyone know how to get the b series tranny on an h22 withouth the h2b.
i konw it can be done, ive seen it and driven it. goddamn it was fast. every gear felt like 1st. i want mine to feel like that
Modified by djsire at 7:53 PM 4/10/2006
djsire
Apr 12, 2006 05:42 AM
