obd2b-obd1 ?
Old Apr 10, 2006 | 08:39 AM
Slow_import's Avatar
Default obd2b-obd1 ?
just have a couple questions i tried to search but nothing related to my problem....i recently got my car converted to obd1 using a chipped jdm p30 with the knock sensor, reve limiter, and governer removed....the problem is the car idles fine and when i drive normally or get on it, i cant get pass 3500 rpm....a check engine light also comes on too....checked the light and its code 16 which is bad fuel injectors....
my question is, is there something on the fuel rail i should disconnect to make the car run properly....i know that on the obd2 b16, theres a sensor on the fuel rail that the older b16's dont have....could it be the problem...any help would be appreciated...thanks
TaikiDC5
Jul 30, 2011 01:17 PM
instrument
11
Sep 1, 2006 09:38 PM
Chronicsinners
25
Mar 7, 2006 03:59 PM
