Back seat removal
Old Apr 10, 2006 | 07:38 AM
confutatis's Avatar
Default Back seat removal
Hello,
My stepson owns a '96 GS-R and needs to be able to remove the back seats to get to the back speakers. He can't seem to figure out how to remove them. If anyone could point him in the right direction, it would be greatly appreciated.
Thanks,
David
Old Apr 10, 2006 | 07:48 AM
Dave_B's Avatar
The tops of the seats on the outside (nearest the black plastic panel you are trying to remove) has a sorta slide like clip to remove the seat backs. Once you get one side out, the other almost falls out. Then you can pull the plastic, no need to remove the seat bottom, but IIRC you can pull that whole plastic piece without pulling the seat backs.
Old Apr 10, 2006 | 08:45 AM
Rtzx9r's Avatar
GDD 1%
Default Re: (Dave_B)
There is a clip on each seat, right on the "hinge" that needs to be removed. It is like a big plastic "C" clip that you can pull out with pliers. Once you do that, just slide the seat to the side and one side will release, then reverse the process and the other side will pop out.
VTEC_PRODUCTION
Dec 15, 2007 07:07 PM
Ckleijne
Oct 29, 2005 11:15 PM
Griff
Apr 15, 2004 08:25 PM
Red!ine
Apr 4, 2004 12:03 AM
FusionITR
Jun 8, 2002 02:14 PM
