Can I use an Integra Brake booster & MC??
Old Apr 10, 2006 | 06:20 AM
Magnum000's Avatar
Default Can I use an Integra Brake booster & MC??
I have a 1995 Integra Brake booster and Master Cylinder. Can I use this on my 91 CRX Si? The booster and MC are from a ABS system, does this matter
Old Apr 10, 2006 | 06:53 AM
CRX Toad's Avatar
Default Re: Can I use an Integra Brake booster & MC?? (Magnum000)
Yes you can you use the Integra booster and mc together and it will go right into your car. I have one in my car, and so do several of my buddies. You will need to change one fitting on the hard line that attaches to the back of the MC. That is also very easy to do. You cannot mix ABS and non ABS equipment.
Old Apr 10, 2006 | 09:42 AM
JohnnieChimpo's Avatar
Default Re: Can I use an Integra Brake booster & MC?? (CRX Toad)
You can use a 95 Teg unit but a 90-93 Teg unit would be easier. That's what I used on mine. When using a DC unit the one line (rear?) gets bent from the driver's side to the passenger side. Bending it is a good way to kink the line and make a whole new nightmare begin. The finished product looks hacked to me. When using a DA, the brake lines don't need rebent from one side to the other just a tiny tweak.
Also, I used a ABS master+booster. It is 1inch like the HypeR. You can either flare on the bigger fitting from the ABS car or use an adaptor like I did. You can get the adaptor at a hydraulics shop. The shop I went to didn't have the exact fitting I needed so I got one that was close and cut a new flare on it with my lathe. It is a thing of beauty now. If I ever get into racing I may swap it back to a 15/16" so I get more pedal feel and because of my adaptor it will be a snap.
Wait till you crawl under the dash to put your booster it. HAHA it is such a bitch it will drive you insane! I nearly threw my wrachet through my windshield I was so pissed.
Old Apr 10, 2006 | 04:27 PM
Magnum000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote"> You cannot mix ABS and non ABS equipment.</TD></TR></TABLE>
This 95 Integra unit I have both MC and booster are from an ABS system. But I want to use on Non-ABS system, will it work or no. Your reply says no.
Old Apr 10, 2006 | 04:51 PM
CRX Toad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magnum000 &raquo;</TD></TR><TR><TD CLASS="quote">
This 95 Integra unit I have both MC and booster are from an ABS system. But I want to use on Non-ABS system, will it work or no. Your reply says no.</TD></TR></TABLE>
My reply says don't mix. Either will work. Use the ABS one it will be just fine it functions no differently than any other one. The ABS one is a 290V, Non ABS 260V, then it goes Civic 230V, and 205V. They higher the vacuum in our cars the less pedals movement needed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Wait till you crawl under the dash to put your booster it. HAHA it is such a bitch it will drive you insane! I nearly threw my wrachet through my windshield I was so pissed.</TD></TR></TABLE>
Oh try putting it on a dual point equiped car and have to drop 3 of the 4 mounts to get it in. PITA!!!!
Old Apr 10, 2006 | 05:22 PM
onePOINTsix's Avatar
i had a 94 Teg RS booster and MC on my crx and it worked fine
Corksil
Suspension & Brakes
Mar 11, 2012 11:01 AM
juba_x
Jan 21, 2011 09:51 PM
mxpx035
Jan 5, 2006 02:16 AM
Another Drew
Jul 4, 2005 06:35 PM
zCivic
May 4, 2004 05:49 PM
