header question
Old Apr 10, 2006 | 04:04 AM
HondaHeddie's Avatar
Default header question
I bought...
http://cgi.ebay.com/ebaymotors...73409
it has no hanger attatchment for the bottom pipe (2 to 1 pipe)
is this correct?
or should I take it to a shop to weld hangers on?
otherwise the entire pipe from the head to midway down the car will have no support other than the manifold studs.
what should I do?
also
the mate from the end of the header to the cat has different size bolt holes and I cannot use the old spring bolts. the kit has plain bolts.
it mates well but should I be worried ?
thanks guys
Old Apr 10, 2006 | 06:52 AM
Default Re: header question (aal)
bump
Old Apr 10, 2006 | 10:30 AM
jdmcars.com's Avatar
Not sure how much you expected for $24.
A header SHOULD be supported, but you will probably be fine without it. More than likely, by welding on a hanger support, you are probably just making another link for that header to rust.
I would re-use the spring bolts. If the holes are not large enough -make them. If they are too large, use a washer.
Old Apr 10, 2006 | 10:58 AM
crxtreme89h's Avatar
Default Re: header question (jdmcars.com)
You really don't need a support bracket. Your stock exhaust support will keep it up. Also, if the bolts don't fit you could drill the holes out to a larger diameter so they do fit, or you could get smaller bolts at a hardware store. Stainless steel with locking washers will do the trick.
Old Apr 10, 2006 | 01:00 PM
Default Re: header question (crxtreme89h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxtreme89h &raquo;</TD></TR><TR><TD CLASS="quote">You really don't need a support bracket. Your stock exhaust support will keep it up. </TD></TR></TABLE>
it is not stock exhaust
it has no connection for a support
eglude
May 27, 2008 04:21 AM
Shaka01
Feb 28, 2006 02:58 PM
dc2Rgirl
Dec 1, 2004 06:51 PM
B00ST2nR
13
Mar 29, 2004 11:28 PM
RISING SUN 1
Apr 29, 2003 10:00 AM
