H22 in CRX.. front heavy O.o
Old Apr 10, 2006 | 01:35 AM
ME-B-N-ME's Avatar
Default H22 in CRX.. front heavy O.o
Ok ok.. first I have looked all over this thread and havnt found a answer to my question. if I have over looked it please send me to it
Anyway.. I wanna swap a H22 into my 90 Crx.. but I have heard stuff from friends.. that its way to heavy for a CRX front in.. one said he did it and.. this and that gave and his front end hit the ground. and another said that it will under or over steer.. or so crap like that.. but then again these are the people who told me that to put Vtec.. on a Honda.. is to put a valve cover that reads Vtec on the engine...anyway.. could someone.. tell me what is needed to keep my crx from nose diving....-_-
Old Apr 10, 2006 | 01:45 AM
SkyliteCustomz's Avatar
"but then again these are the people who told me that to put Vtec.. on a Honda.. is to put a valve cover that reads Vtec on the engine...anyway.. could someone.. tell me what is needed to keep my crx from nose diving....-_- "
u have some dumbass friends..lol but yea umm im interested in this topic myself..i heard somewhere that you would need to cut the firewall in order to get the motor to properly fit..iono
Old Apr 10, 2006 | 01:47 AM
b.d.racing's Avatar
Default Re: H22 in CRX.. front heavy O.o (ME-B-N-ME)
Go to Hasport.com they have the answers you're looking for and if you don't figure it out on they're site call them.
Old Apr 10, 2006 | 01:59 AM
ME-B-N-ME's Avatar
Default Re: H22 in CRX.. front heavy O.o (b.d.racing)
Yes very stupid.. but I guess its off to Hasport.com thanks much
Old Apr 10, 2006 | 02:45 AM
yz125rider21's Avatar
also ryan from rywire could answer questions on this cause sure its the same as a k20 swap...
Old Apr 10, 2006 | 03:27 AM
black_krix_si's Avatar
Default Re: (yz125rider21)
Your front end wont do a nose dive. I suggest finding new friends. I just put a H22 in my crx on :gasp: factory suspension. I think it came down less than inch....if that.
Wiring isnt that hard either. If you have an HF or Si your almost set. I used my Si harness extended the alternator wires and that was pretty much it. The JDM H22 uses low impedance injectors like the crx so i didnthave to switch those and I can keep the resistor box.
Old Apr 10, 2006 | 11:27 AM
ME-B-N-ME's Avatar
Default Re: (black_krix_si)
Hmmm I dont think I will get new friends.. just stop listing to them.. and come here with all my questions and what not XD but thanks once more.. I guess its off to find a H22 for cheap
Old Apr 10, 2006 | 11:45 AM
drachir's Avatar
Do a search for H22 weights. Someone here on Honda-tech actually weighed B, D, and H series motors. Difference in weight between B and H was negligible.
Don't listen to all the BS about H series significantly throwing off weight distribution.
Old Apr 10, 2006 | 12:07 PM
JODA GOT SOL's Avatar
hasport
Old Apr 10, 2006 | 12:15 PM
crxforum's Avatar
Default Re: H22 in CRX.. front heavy O.o (EK JODA)
Youre looking at a 40-60lb weight difference between H and B series. Its nothing major and the torque is worth it.
CRX Forum
Old Apr 10, 2006 | 02:34 PM
ExplicitSpeed360's Avatar
Banned.
Default Re: H22 in CRX.. front heavy O.o (crxforum)
The weight difference is very minimal from a chubby GSR and a H22. About 30 lbs difference. My 90 crx hf H22A weighed in at 2000 lbs without me in it. Please check out my site for all the EF H22A how to. We also make the EF H22A motor mount kit...
http://www.ExplicitSpeedPerformance.net
Old Apr 10, 2006 | 02:46 PM
Go n 4 10s's Avatar
Hummm.... H22 in a REX= F$ckin fast azz hell!!!!! I watched a rex with a H22 with I H E run 13.2 at like 111 or something like that, DO IT!!!!!!
Old Apr 10, 2006 | 03:09 PM
YasRex's Avatar
Adding weight to your call will always affect handling. Especially if you don't upgrade and tune the suspension to balance the car out. Having a heavy nose is a bad thing for handling.
Also remember that adding weight means that you need more torque to pull the car around. Look up engine weights, you will gain about 100 lbs with that engine. Depends on how much you like to corner.
Old Apr 10, 2006 | 06:46 PM
Default Re: H22 in CRX.. front heavy O.o (YasRex)
Try a SEARCH.
Wait I'll do it for you
https://honda-tech.com/zerothread?id=684550
Old Apr 11, 2006 | 02:10 AM
ME-B-N-ME's Avatar
Well I have my mind set on doing this swap, and yes I like to corner alot.. its liek the best thing to do.. so I guess Im going to have to look into suspension aswell to balance me car hmm ok then no worries I think I can handle that
Old Apr 11, 2006 | 07:37 AM
CRX Toad's Avatar
A way to reduce the weight on this swap a little bit is to use the H to B adapter plate to mate the H series to the B series tranny.
Old Apr 12, 2006 | 12:06 AM
ME-B-N-ME's Avatar
Default Re: H22 in CRX.. front heavy O.o (CRX Toad)
Hmm where do I get such a plate O.o
Old Apr 13, 2006 | 10:13 AM
Banned.
to keep the facts right and straight up the weight difference between a H series tranny and a B series tranny is about a 1 lb lol for street and track H series tranny! track only B series, difference in the 1/4 mile between the two trannies tenths of seconds not seconds a set of cams or a good tune will cover the difference...
JDM H22 LSD M2B4 tranny
540i6
Jan 8, 2005 06:40 PM
crxh22project
12
Aug 30, 2004 08:21 PM
4g4drb17
May 12, 2004 08:21 AM
red_crx_89
Mar 9, 2004 12:31 AM
azn_boi
May 22, 2002 10:01 PM
