NEED HELP WITH BRAKES!
Old Apr 9, 2006 | 11:19 PM
S2KBAR's Avatar
Default NEED HELP WITH BRAKES!
I'm trying to buy a rotor/pad set but its very difficult to specify to the seller which pad is compatible with my 94 del sol VTEC (b16 DOHC). I just wanted to know if any other honda or acura uses the same pad. Thank you.
Old Apr 10, 2006 | 12:53 AM
ondahush's Avatar
duralast works for me the one that is made out of khevlar and when its hot it glows
Old Apr 10, 2006 | 01:10 AM
nello a.'s Avatar
if the seller is that stupid, use someone else. hawk or ebc are good. i think pep boys sells both(dont know if u have that there)
Old Apr 10, 2006 | 01:22 AM
BlueIntegraBoy's Avatar
Default Re: NEED HELP WITH BRAKES! (B16 Turbo Del Sol)
Contact Ken '88Rotors', he can hook you up with Brembo rotors and PBR pads.
For the rear pads, you can get them from a 90-01 Integra, 92-95 Civic EX/Si, 93-97 Del Sol Si, and 99-00 Civic Si.
For the front pads, I believe 94-01 Integra pads will work.
Old Apr 10, 2006 | 02:50 AM
fmrprojects's Avatar
Default Re: NEED HELP WITH BRAKES! (BlueIntegraBoy)
i have PBR ceramic pads and they are sick. stops better than any other pads i've used. just leaves a little more brake dust on your rims
NOOdS
Jun 4, 2008 03:12 PM
Ch3miztry
Mar 17, 2005 04:46 PM
C_I_V_I_C
May 19, 2003 07:32 PM
YodaIsGod
27
Jul 13, 2002 06:40 PM
