NEED HELP WITH BRAKES!
I'm trying to buy a rotor/pad set but its very difficult to specify to the seller which pad is compatible with my 94 del sol VTEC (b16 DOHC). I just wanted to know if any other honda or acura uses the same pad. Thank you.
Re: NEED HELP WITH BRAKES! (B16 Turbo Del Sol)
Contact Ken '88Rotors', he can hook you up with Brembo rotors and PBR pads.
For the rear pads, you can get them from a 90-01 Integra, 92-95 Civic EX/Si, 93-97 Del Sol Si, and 99-00 Civic Si.
For the front pads, I believe 94-01 Integra pads will work.
Re: NEED HELP WITH BRAKES! (BlueIntegraBoy)
i have PBR ceramic pads and they are sick. stops better than any other pads i've used. just leaves a little more brake dust on your rims
Ch3miztry
03-17-2005 04:46 PM
YodaIsGod
27
07-13-2002 06:40 PM
