Suspension & Brakes Theory, alignment, spring rates....
if you're lowered at all... read me
Old Apr 9, 2006 | 09:57 PM
the soL that could's Avatar
Default if you're lowered at all... read me
i noticed at first when i had my H&R race springs on stock struts i would feel every crack, bump, pothole... on the road.
here's my issue: now, i'm running H&R race springs w/ KONI yellows and it still feels the same way? it handles hell of alot better but when i drive on rough roads, i'm still getting that loud *** clunk. i took off the top of my del sol just to see if it was that but i was wrong. why is my suspension making this noise?
i searched... and i read "trailing arm bushings" all my bushings from upper to lower control arm are good. trailing arms, UCA, LCA... none ripped.
i also read that alot of people are experience this noise/feel when they're lower than 2 inches. any suggestions or am i completely normal?
Old Apr 9, 2006 | 10:13 PM
sportyaccordy's Avatar
Which end of the car is it coming from? 9/10 loud sounds on compression= your front UCA's hitting the shock tower. No way around it if you're super low, and it can mess up your UCA's to the point that the balljoint gets knocked out. Gotta pay to lay low.
Old Apr 10, 2006 | 07:01 AM
hawjboi's Avatar
Default Re: (sportyaccordy)
yeah my cars hitting the top of my shock tower and i took a look and the ball joint is about to come off...i'm going to weld it on so it doesnt come off...and only enough so i can grind it down to replace whenever i need too...
when i turn my yellows to full soft the clunk that you describe goes away but when its not at full soft i can feel and hear that clunk your talking about...try turning the shock to full soft if you havent done soo..
Old Apr 10, 2006 | 07:18 AM
it's comming from my rears... i hear it from the back for some reason.
Old Apr 10, 2006 | 08:00 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (the soL that could)
I am very low, and I get no clunks (Koni GC 400f/250r at -3")...
Perhaps it's your rear sway-bar. These tend to make some noise if something is loose...
Wish I could be of more help...
Old Apr 10, 2006 | 08:33 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I am very low, and I get no clunks (Koni GC 400f/250r at -3")...
Wish I could be of more help...</TD></TR></TABLE>
i read in that other thread... everybody with a del sol has the same problem. i swear, i'm about to weld everything together lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hawjboi &raquo;</TD></TR><TR><TD CLASS="quote">
when i turn my yellows to full soft the clunk that you describe goes away but when its not at full soft i can feel and hear that clunk your talking about...try turning the shock to full soft if you havent done soo..</TD></TR></TABLE>
weird. i hear it on both softest and stiffest
the171
Jul 6, 2009 07:17 AM
mbdm
Aug 3, 2008 09:20 PM
SiR99
Jul 11, 2006 03:20 PM
the soL that could
12
Apr 28, 2006 08:57 PM
Blade_Irl
May 23, 2003 09:09 AM
