Suspension & Brakes Theory, alignment, spring rates....
Need help!!!...can i run ABS with 4x114.3 suspension
Old Apr 9, 2006 | 09:51 PM
XxSOHCDriVerxX's Avatar
Default Need help!!!...can i run ABS with 4x114.3 suspension
Just like the topic says....is there a way that i can run my existing ABS system if i do a 4x114.3 conversion? I have a 95 civic EX with ABS.
--Henry
Old Apr 10, 2006 | 04:25 PM
Default Re: Need help!!!...can i run ABS with 4x114.3 suspension (XxSOHCDriVerxX)
ttt
Old Apr 11, 2006 | 06:01 AM
anyone?
Old Apr 11, 2006 | 05:45 PM
65465
Old Apr 12, 2006 | 10:07 PM
damn no tech...this site sucks
Old Apr 12, 2006 | 11:40 PM
slammed_93_hatch's Avatar
that completly depends on if the 1996 ITR had abs.
If it did, then you can run it, if it didn't then you can't.
the hubs front and rear have these little ribbed area's (looks like a sprocket), and a sensor fallows that, and that is what engages the ABS.
Just an FYI, the only thing you are getting with this swap is a different bolt pattern. The brakes will be the same size as your car.
Old Jul 10, 2006 | 10:42 AM
Rcp's Avatar
Rcp
so is it possible to drill holes onto the knuckle to hold the abs sensor in place?
josh-roy
Jul 30, 2010 02:32 AM
95jdmcivic
May 27, 2008 11:41 AM
skiptomylou
Apr 13, 2006 06:09 AM
egb18c5
Dec 19, 2005 06:25 PM
Fraggle
Nov 2, 2003 11:03 AM
