1992 Hatchback Wheel Hub question.. **HELP**
Old Apr 9, 2006 | 09:43 PM
MISHN's Avatar
Default 1992 Hatchback Wheel Hub question.. **HELP**
i have a 92 hatch VX. i just changed my front rotors and pads. i noticed when i changed my tires my wheel hub shakes when my car is off the ground as if a bearing is messed up. it was never like this before. now both sides have this problem. when i drive my car it doesnt shake at all. rides fine but im just scared to drive it knowing that it seems loose. i checked my friends wheel hub and it wasnt loose like mine was. does anyone know what the problem could be? thanks.
Old Apr 10, 2006 | 01:14 PM
MISHN's Avatar
Default Re: 1992 Hatchback Wheel Hub question.. **HELP** (EG6 RITZ)
anyone? help...
Old Apr 10, 2006 | 01:39 PM
GBRacing's Avatar
If the front hub bearings are original, then they'll need replacing. If a bearing where to fail on you, it will leave you stranded in the middle of the road with the potential of quite a bit of damage. Best to have them replaced.
Old Apr 10, 2006 | 04:09 PM
MISHN's Avatar
Default Re: (GBRacing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GBRacing &raquo;</TD></TR><TR><TD CLASS="quote">If the front hub bearings are original, then they'll need replacing. If a bearing where to fail on you, it will leave you stranded in the middle of the road with the potential of quite a bit of damage. Best to have them replaced.</TD></TR></TABLE>
what would happen if the bearing went out on me? will it make a sound or just stop rolling?
Old Apr 10, 2006 | 07:05 PM
GBRacing's Avatar
Your wheel would seized on you. When that's happen to a few friends of mine on the racetrack, the've all ended up in a tire wall with lots of damage. The price to fix way outweights the damage they can cause.
Another solution would be to swap an entire front knuckle/brake caliper to something newer like 99 Civic SI, GSR, etc.
nightrider
Jul 24, 2009 07:02 PM
RTW DC2R
Mar 25, 2008 06:10 PM
famousbadboi
Mar 24, 2008 12:55 PM
spoolin_teg
Mar 8, 2007 04:26 PM
ITR-00-1457
Dec 14, 2004 02:38 PM
