help with suspension and steering rebuild
Hi ppl, I am currently looking for this bushing (circled in red):
and also, to replace the rack end bushing, you also need to replace a washer...
the bushing that im changing is #10
but I dont know which washer is the one that I need to replace... LMK THANKX
check on here..
http://www.energysuspension.com/
i'm almost certain i've seen that setup with the energy suspension bushing's, i would personally go for these poly bushings over te stock old rubber crap...
hopefully this helped..
I can't see OEM rubber holding much longer either. IIRC, to get rubber replacements for the rear trailing arm, you need to get the mugen ones. King motorsports is the cheapest, as well as teh only inporter/distributor.
As 'amazing' as the word OEM makes things, rubber is rubber. You can bet if they used any synthetic rubber like viton, you'd be paying though the nose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pakipr »</TD></TR><TR><TD CLASS="quote">but I dont know which washer is the one that I need to replace... LMK THANKX </TD></TR></TABLE>
#22 is the lock washer.
just replace the trailing arm bushing with OEM. its cheap enough, like $25 now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">#22 is the lock washer.
just replace the trailing arm bushing with OEM. its cheap enough, like $25 now.</TD></TR></TABLE>
where ? I tried http://www.hondaautomotiveparts.com and didnt had any luck
part # is 52385-S21-003
thrill91si
May 16, 2003 09:34 AM
