steering vibration on highway
Old Apr 9, 2006 | 04:39 PM
Rob.'s Avatar
Default steering vibration on highway
So I have had this problem for a while now.
So far I have done :
- New steering rack (fixed another problem with clunking lol)
- outer tie rods
- front wheel bearings
- alignment twice
- balance wheels twice
- checked entire front end , seems fine
what could be the problem ?
1 thing I have to check is trying out another set of wheels to see if that is
what is causing the steering vibration..
any other suggestions ?
Modified by Rob. at 8:36 PM 4/9/2006
Old Apr 9, 2006 | 04:43 PM
91B16HF's Avatar
Default Re: steering vibration on highway (Rob.)
steering shaft itself maybe? that seems to be one thing you haven't touched yet.
Old Apr 9, 2006 | 04:48 PM
Jonny Black's Avatar
Default Re: steering vibration on highway (91B16HF)
tires out of round maybe?? sure you can balance an egg...but its still an egg.
Old Apr 9, 2006 | 04:49 PM
Rob.'s Avatar
Well, Im gonna test another set of wheels to see if thats the problem.
Old Apr 9, 2006 | 07:37 PM
Rob.'s Avatar
bump
any more ideas ?
Old Apr 9, 2006 | 07:56 PM
saver's Avatar
i have some of the same problems also. on the highway on a turn somtimes i feel like in the middle of the turn it doesnt want to turn no more. then i also have the clungking noise to. hopfully this thread helps me aslo. somtimes i feel like im ganna regreat buy my civic si.
Old Apr 9, 2006 | 08:02 PM
Bjorn20's Avatar
Default Re: steering vibration on highway (saver)
i had the exact same problem, of where it go to the point of around 70 mph or so, the hood, drivers door, steering wheel, shifter would vibrate and shake violently. i then rotated and got my tires balanced, the problem is gone.
but couple months later (now) the car is kinda making noises under accel after around 40, guessing my gay *** tires need another balance or something , thats what you get for driving a 15 year old car, always going to have problems.
Old Apr 9, 2006 | 08:36 PM
91B16HF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saver &raquo;</TD></TR><TR><TD CLASS="quote">i have some of the same problems also. on the highway on a turn somtimes i feel like in the middle of the turn it doesnt want to turn no more. then i also have the clungking noise to. hopfully this thread helps me aslo. somtimes i feel like im ganna regreat buy my civic si.</TD></TR></TABLE>that sounds like a bad rack to me. Does it feel like it locks up or it just itatching anything?
Old Apr 9, 2006 | 08:50 PM
saver's Avatar
ya for a while during the turns.
Old Apr 9, 2006 | 09:01 PM
eda6's Avatar
i have steering vibration on the highway. I believe my problem is caused by bad front upper ball joints. when i checked out the front end everything was solid but the right front upper ball joint knocked and i hear the same knock when i'm driving on crappy roads and going over bumps.
Old Apr 9, 2006 | 09:07 PM
HBK's Avatar
HBK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">Well, Im gonna test another set of wheels to see if thats the problem.
I'm gonna quote you on this one. Make sure to post multiple threads about it in appearance.
Old Apr 9, 2006 | 09:12 PM
Reza^'s Avatar
Default Re: steering vibration on highway (HBK)
new tires
Old Apr 10, 2006 | 11:46 PM
saver's Avatar
Default Re: steering vibration on highway (R.Yaghoubi)
not to steel this thread but sorta on the same subject. umm...i have 2 diffrent size of tires and rims on my car then the other 2. i had to put the (sorta larger size) tires up front. since i did that my car is leveled out all wack. i bought the car with cut springs up front and some aftermarked springs in the back. there both not that low. this also happens to, when i lift the car up with a jack when i need to and then drop it, it ends up in a diffrent level. its like i have imaginary living air bags.
Old Apr 10, 2006 | 11:50 PM
Immanuel's Avatar
I had the same problem as well. My front driver side rim lip was bent a lil bit. I would drive on the freeway 70 or so, it would feel like I was holding a jackhammer as a steering wheel I rotated my bent rim to the back, the problem is gone So I guess tires and rims check those again
Old Apr 11, 2006 | 12:16 AM
saver's Avatar
Default Re: steering vibration on highway (1.6 DOHC ED9)
http://www.angelfire.com/d20/hcivic88/4gtech.html
and go down to where it says how to remove the steering rack out. this will help a lot if you have the same problem.
Modified by saver at 10:33 AM 4/11/2006
CraiGlOl
Jun 2, 2010 06:30 PM
bmoua
Aug 20, 2007 01:46 PM
josh807
Jul 23, 2007 11:16 AM
rinard
Mar 26, 2004 09:23 PM
