H22 sensors
I need to replace various sensors...like the coolent sensor....where would I buy this part at? honda dealership? or is there somewhere cheaper. ..and can someone give me an idea of how much a coolent sensor costs? how about a o2 sensor for the cat....?
actually now I only need a coolent sensor...and another sensor i'm not sure about...right now i'm just going to focus on the coolent sensor. I need them because when I was taking an old engine harness off of the engine....the damn sensors just desentigrated and pulled a part.
damn that's crazy.
now are you talkin about the sensor in the coolant housing to turn on the fan, or are you talkin about the sending unit in the engine??
damn that's crazy.
I'm guessing it would be called the sending unit? I'm not sure. It screws into the left side of the engine(as if your looking at the front of the engine). And a plug on the main engine harness plugs into it.
ya, the lil booger that is under ur distributor.
a wire hooks onto it and tells u the temp on ur gauge cluster how hot the coolant is.
go to checker, or autozone and they have that.
that's easy as hell to replace
Tryk
Sep 1, 2004 03:43 AM
