Torque specs with diff gasket!!!!
Old Apr 9, 2006 | 01:21 PM
z6_EF_obd1's Avatar
Default Torque specs with diff gasket!!!!
Okay I searched but found no luck.
I'm rebuilding a z6 I had laying around ALL stock exept for a y8 intake mani.
I want to run 7 pounds of boost on it. According to the Compression Calculator found in the FAQ forum, a d16a6 head gasket will lower my comp .2 from 9.14:1 to 8.94:1. However, if i wanna do this should I torque the z6 head to the z6 block using the torque specs for the a6 or the z6? I just want a lil lower comp to be on the safe side.
Thanx in advance
Old Apr 9, 2006 | 01:55 PM
HatchWarehouse's Avatar
Default Re: Torque specs with diff gasket!!!! (z6_EF_obd1)
I think you should just use the z6 head gasket. My $.02
CR-V-tech
Apr 15, 2006 03:15 PM
chippy
Mar 3, 2006 03:56 AM
97grnrs
Dec 10, 2005 11:11 AM
Greg123
Feb 7, 2003 07:26 PM
