91 Accord EX Front Wheel Bearing?
Old Apr 9, 2006 | 01:00 PM
cchrisj's Avatar
Default 91 Accord EX Front Wheel Bearing?
Front end makes low whirling noise when moving--sounds like the tire tread is rubbing against the inside of the wheel well, but it's not. It is worse when the steering wheel is turned slightly one way than the other. The faster you go, the louder it is--from barely noticeable while creeping to a roar at 60 MPH.
Diagnosis? Wheel Bearing?
Parts? Any special tools/techniques needed--I'd like to repair it myself.
Thanks.
Old Apr 9, 2006 | 01:09 PM
BLKFLSH's Avatar
Default Re: 91 Accord EX Front Wheel Bearing? (cchrisj)
One easy thing to check out. Look behind the rotor to see if maybe a rock or something is jammed in between the rotor and the shield.
Old Apr 11, 2006 | 08:02 PM
cchrisj's Avatar
Default Re: 91 Accord EX Front Wheel Bearing? (BLKFLSH)
We will check, hoping it is that easy a fix.
TXaggie
Jul 24, 2018 12:49 PM
Jcull35
Jun 3, 2017 03:36 PM
EJ8mike
Mar 13, 2013 06:28 PM
Bad_dude
Apr 1, 2009 11:41 PM
egrichie
Jan 17, 2005 11:12 PM
