Squeal when turning
Squeal when turning
I have a 04 Honda Accord with low miles on it (44k). A few days ago my left front wheel started squealing when making turns in motion only, both braking and not braking . It sounds like a wear indicator on brake pads.That's the only time it makes any kind of noise, it's generally a quite car. I took the wheel off to look at the brakes and everything looks fine. What else can it be?
I never narc'd on nobody!
Re: Squeal when turning
Put the front end on jack stands. Grab the wheel at 3 and 9, and try to wiggle it. Now grab it at 12 and 6 and try to wiggle it. If it has play in both directions, your wheel hub bearing is probably shot. Prolonged sitting (decent possibility for a 13 year old car with only 44k on it) can also fry a wheel hub bearing.
TXaggie
07-24-2018 12:49 PM
