Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
06 CRV Satellite antenna
Old Apr 9, 2006 | 11:28 AM
Honda Tool's Avatar
2010 Honda-Tech Poker champion
Default 06 CRV Satellite antenna
Any body know if it is possible to use the factory XM antenna with Sirius? I have checked behind the head unit, and do not see the antenna hookup. Where would it be wired too?
Old Apr 10, 2006 | 04:50 AM
Ross 2.0's Avatar
In a Junkyard near you.
If your CR-V is equipped with factory XM or acessory XM?
Old Apr 11, 2006 | 02:05 PM
Honda Tool's Avatar
Default Re: 06 CRV Satellite antenna (Noles)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Noles &raquo;</TD></TR><TR><TD CLASS="quote">Any body know if it is possible to use the factory XM antenna with Sirius? I have checked behind the head unit, and do not see the antenna hookup. Where would it be wired too?</TD></TR></TABLE>
Factory XM Radio/Antenna. Head unit is Factory XM ready. Did not get the optional XM tuner, but has the Antenna. I want to use a Sirius add on tuner, but would like to use the XM antenna. Looks dumb with 2 on the roof.
Old Apr 11, 2006 | 06:23 PM
Ross 2.0's Avatar
I'm pretty sure that's just a dummy box. The antenna comes with the kit. But just to be sure pull down the back headliner enough to see the bottom of where the box is. If you see the wire it's there but I don't think it is.
Old Apr 11, 2006 | 07:45 PM
Honda Tool's Avatar
Default Re: (MooGoCow3)
Yeah you are right it is just a cover. And the connection is totally different than a sirius receiver. Might try to find a sirius antenna that will work. Thanks
Old Apr 12, 2006 | 07:31 AM
Ross 2.0's Avatar
If your lucky you may be able to use that mounting point instead of having two black boxes. Also consider painting it to match the body.
GreenGSR
Audio / Security / Video
Feb 5, 2005 08:08 PM
2K_TEG
Sep 23, 2003 03:33 PM
crewjones
May 9, 2003 09:37 PM
Julian
Jul 26, 2002 01:13 PM
hydroflip
Nov 29, 2001 09:54 PM
