obd1 b16a to obd0 crx
can i use the harness from my d16 obd0 motor and plug it into the b16a obd1 and run the extra wires from the obd0 to obd1 ecu jumper harness....
so i could use my 89 crx si obd0 non vtec harness to plug into my obd1 b16 motor and just use the ecu jumper harness.....
Yes you can, however you need to swap your dizzy plugs for some obd1 gray plugs the wire colors basically match each other exept for the obd0 large white wire that goes with the obd1 yellow/green wire.
DONE!!!
DONE!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchWarehouse »</TD></TR><TR><TD CLASS="quote">Yes you can, however you need to swap your dizzy plugs for some obd1 gray plugs the wire colors basically match each other exept for the obd0 large white wire that goes with the obd1 yellow/green wire.
DONE!!!
If your dizzy is oem honda
DONE!!!
</TD></TR></TABLE>If your dizzy is oem honda
what do you mean if my dizzy is oem.... thedizzy plug is the two big round obd0 plugs on the passanger side under the hood right?????
crx_si-r
Feb 26, 2010 07:48 AM
aser1z
May 7, 2006 06:34 PM
