Honda S2000 Honda S2000
My S2K won't start!! :(
Old Apr 9, 2006 | 09:59 AM
CBS2000's Avatar
Default My S2K won't start!! :(
Hey Guy's, I went to start up my car today after storing it for winter ... the car has not been started in about 2 - 3 months ... when I hit the start button it won't turn over it just makes a repeated clicking sound ... I tried charging the battery but that did not help out ... any ideas on how I can get my S going would be greatly appreciated.
Old Apr 9, 2006 | 11:46 AM
SpoonS2KMe's Avatar
Default Re: My S2K won't start!! :( (CBS2000)
it could be a number of things... did you get a new battery or a different battery? the gas is probably bad in it... and theres other's i can't think of...
hope that helps
Old Apr 9, 2006 | 12:02 PM
LAS2K's Avatar
Default Re: My S2K won't start!! :( (SpoonS2KMe)
what kind of conditions was it stored in?
battery is only thing that comes to mind. no cranking over noise just clicking...
did you disconnect anything while storing it?
Old Apr 9, 2006 | 12:05 PM
Chubz's Avatar
Default Re: My S2K won't start!! :( (LAS2K)
battery shot,
Old Apr 9, 2006 | 12:12 PM
Mr. Projekt's Avatar
* B A N N E D *
Check fuses?
Old Apr 10, 2006 | 02:03 AM
xc1097's Avatar
could be your immobilizer
my friend's car had that problem w/ his MY00
ended up getting the key reprogramed
Old Apr 12, 2006 | 07:34 AM
CBS2000's Avatar
Thanks for the reply guy's ... I'm gonna go pick up a new battery today ... should I go with the stock battery or try something different?
Old Apr 12, 2006 | 11:20 AM
madcowdk's Avatar
Default Re: My S2K won't start!! :( (Chubzilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chubzilla &raquo;</TD></TR><TR><TD CLASS="quote">battery shot, </TD></TR></TABLE>
Old Apr 12, 2006 | 11:37 AM
Speed Monkey's Avatar
Default Re: (CBS2000)
Stock battery is fine unless you have electrical mods (stereo). Then get a yellowtop. Or just get a yellowtop as they look cool.
Probably not the immobilizer as if that was the case, the car will crank but just not turn over.
Have Autozone check the old battery for a bad cell, otherwise maybe it only needs a recharge.
Old Apr 12, 2006 | 11:47 AM
evil vapor's Avatar
Default Re: (Speed Monkey)
Really good chargers go a long way in charging a battery that's completely dead. You might get away with charging the battery. Then again, a new battery is half or a third the cost of a professional charger
Old Apr 12, 2006 | 07:58 PM
WillieMaoLu's Avatar
Default Re: (vapor)
See if you have a friend and actually swap the battery to see if it is the battery first, you wouldn't wanna go to the shop and get a new battery but that really isn't the problem, I agree with the person that said if there isn't the cranking and the sounds then it may be electrical. Also you may wanna check your button, I've had someone go through hell trying to find out what was the problem then he finally went to the dealer they told him something was wrong with the button they just had to fix something on the other side.
Old Apr 13, 2006 | 03:58 PM
mattb1's Avatar
Default Re: (WillieMaoLu)
did you find out what has happened yet?
sixfourkiller
Jun 17, 2009 10:05 AM
Hatchman98
Apr 24, 2007 06:54 AM
LaOstha
17
Feb 21, 2005 02:15 PM
my ride
Jul 21, 2004 10:40 PM
