Suspension & Brakes Theory, alignment, spring rates....
Rear Lower tie bar. ?
Old Apr 9, 2006 | 09:55 AM
EJ294coupe's Avatar
Default Rear Lower tie bar. ?
im thinkin of doing minor suspension..any input on which would be the best lower tie bar?..a few people said DC Sports arent bad..but i just wanted a second opinion.
Old Apr 9, 2006 | 10:39 AM
rockdude14's Avatar
either comptech or asr piece are probably the best
you can also mount a sway bar to those that wont break the rear subframe which will improve handeling 100x more than just the brace
Old Apr 9, 2006 | 10:54 AM
EJ294coupe's Avatar
thanx rockdude14. ill keep that in mind.
Old Apr 9, 2006 | 11:16 AM
PIC Performance's Avatar
Default Re: Rear Lower tie bar. ? (EJ294coupe)
A lower tie bar is not the same thing as subframe reinforcement. A lower tie bar will not doing anything to improve handling, and AFAIK there is no design out there that is a good subframe reinforcement either.
ASR's subframe reinforcement looks to be the best on the market. How necessary it is depends on how aggressive you go with the swaybar, what chassis you have (I think the EK's are more prone to subframe tearout), and your rear spring rates.
Old Apr 9, 2006 | 11:42 AM
EJ294coupe's Avatar
i have the EJ2
Old Apr 9, 2006 | 11:48 AM
Default Re: (EJ294coupe)
I would still be careful, as it can happen for the 92-95 as well. There are a couple diff variables and afaik there's relatively few well documented occurences, so there is no hard-and-fast rule as to if and when you will experience it.
The only good rule to go by is "better safe than sorry". You really don't want your subframe to tear. I would consider the subframe brace piece of mind if nothing else, and if you ever did decide to run a more aggressive rear setup, you would be all set.
Old Apr 9, 2006 | 12:13 PM
EJ294coupe's Avatar
ok sounds good..where could i find the ASR SFB?
Old Apr 9, 2006 | 01:13 PM
rockdude14's Avatar
pic you wouldnt call the comptech bar a lower tie bar?
it connects both lca with a solid piece of aluminum
Old Apr 9, 2006 | 01:35 PM
Voyage34's Avatar
Default Re: (rockdude14)
it does stiffen as a tie bar, but its primary function is to reinforce the subframe against tearout due to a large rear sway bar. the tie bar-ness is just a bonus
*edited because i realized i spelled large Karge*
Modified by Voyage34 at 6:33 PM 4/9/2006
Old Apr 9, 2006 | 05:28 PM
suspendedHatch's Avatar
Default Re: (Voyage34)
If you get a good swaybar, you don't need subframe reinforcement. Progress rear adjustable
Old Apr 9, 2006 | 07:26 PM
No, I said I wouldn't call a lower tie bar a subframe reinforcement. The piece has to do a lot more than connect the two points.
Old Apr 9, 2006 | 07:34 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ294coupe &raquo;</TD></TR><TR><TD CLASS="quote">ok sounds good..where could i find the ASR SFB?</TD></TR></TABLE>
You can find this at http://www.passwordjdm.com
Old Apr 10, 2006 | 10:50 AM
rockdude14's Avatar
opps my bad i thought you meant you wouldnt call comptech's piece a lower tie bar
ya paswwordjdm has the asr piece at a good price
also if you dont want comptechs whole package with sway bar you can buy just the tie bar
sol_1
Feb 25, 2007 05:30 PM
EricUSC
Nov 5, 2003 09:09 AM
sfr4dr
Feb 12, 2003 10:42 PM
ARACER25
May 4, 2002 06:22 AM
carsaregood
16
Apr 22, 2002 08:39 PM
