b16 swap need to swap the 89dx hubs for 91 teg hubs for the axles PLEASE HHHHHEEELLLPPPPP...........
I am swaping a motor and I need to know how hard it is to take the 91 teg hubs and swap them on my 89 civic dx..............PLEASE HELP>?
why are u swapping them?? the DX hubs are 26 spline. the teg axles will go right in there. the only time u need to swap is when u put a b series into a STD hatch or a crx HF. they have the 23 spline hubs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 »</TD></TR><TR><TD CLASS="quote">I am swapping a b16 into it........</TD></TR></TABLE>
and what i think I Have an STD is saying, is that that you dont need to sway the hubs over because the b16 axles will fit just fine with the dx hub
kool that will be awesome is their a way I can check,,,,count the splines or any other way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote"> the DX hubs are 26 spline. the teg axles will go right in there.</TD></TR></TABLE>
counting would seem to be the way to go - easy and free
if your hatchback is a 5 speed (not 4 speed) then you DEF have 26 spline hubs. b16 axles will fit right in there with no modifications
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Have an STD »</TD></TR><TR><TD CLASS="quote">why are u swapping them?? the DX hubs are 26 spline. the teg axles will go right in there. the only time u need to swap is when u put a b series into a STD hatch or a crx HF. they have the 23 spline hubs</TD></TR></TABLE>
my homie has a STD 90 hatch with a LS swap, all he needed were the Si/DX hubs to work. Pretty cheap from a junk yard
MEBHB91
Jul 27, 2006 11:10 PM
Tuner Eddy
Mar 18, 2005 10:23 AM
Arbiter
Dec 9, 2004 04:38 PM
joey1320
Feb 17, 2003 01:25 PM
