where did the DOHC ZC come from?
Old Apr 9, 2006 | 06:17 AM
racingcrx's Avatar
Default where did the DOHC ZC come from?
make model year.
Old Apr 9, 2006 | 06:46 AM
Autoworks's Avatar
Default Re: where did the DOHC ZC come from? (racingcrx)
https://honda-tech.com/zerosearch
Theres a post identical to your question, between pg. 1and 3 in this forum
Old Apr 9, 2006 | 07:07 AM
Ahks's Avatar
Default Re: where did the DOHC ZC come from? (Autoworks)
the only problem with searching for ANYTHING about ZC's on this forum is
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Search &raquo;</TD></TR><TR><TD CLASS="quote">The following words are too short or too common and were not included in your search: zc</TD></TR></TABLE>
I ran into this problem while researching an engine swap for my rex a while back
You can still find the info you are looking for its just a bit harder...
better off using google and phrasing your search like this
"site:honda-tech.com your search here"
that way google will search H-T and you can bypass the slight lameness of the H-T searcher :D
Old Apr 9, 2006 | 07:09 AM
Autoworks's Avatar
Default Re: where did the DOHC ZC come from? (Ahks)
I always search "DOHC ZC"
racingcrx's Avatar
so have I
Old Apr 9, 2006 | 07:11 AM
racingcrx's Avatar
they should make a website where you can find the number under the name of the motor and where it came from what year make and model. Is there any website that does that?
Old Apr 9, 2006 | 07:13 AM
Ahks's Avatar
http://www.hondaswap.com/forum...29825
is what i use when i have a question... it might be wrong tho
Old Apr 9, 2006 | 09:59 AM
racingcrx's Avatar
seen it before. ZC has come in many cars and I want to find out where mine came from
IP RACING
Nov 29, 2006 05:47 PM
illistEF
16
Nov 8, 2006 09:55 AM
SleepstR88
Mar 8, 2006 07:48 AM
efracer
Aug 30, 2004 08:52 PM
sickciv
May 13, 2003 08:04 PM
