fuel pressure regualtor questions
Old Apr 9, 2006 | 03:57 AM
zenon8890's Avatar
Default fuel pressure regualtor questions
hi HT, i just installed a fuell pressuer regulator and i wanna make sure that i installed it right, i took a picture and plz i wanna know if its wrong or not, and how much prussure should i open
Modified by zenon8890 at 3:41 AM 4/23/2006
Old Apr 9, 2006 | 11:21 AM
CBURKE's Avatar
Looks good to me, and 10% of what the stock psi is good. so like 38-40. It kinda depends on what mods you have.
Old Apr 21, 2006 | 04:34 PM
project_K's Avatar
Default Re: fuel pressure regualtor questions (zenon8890)
does your gauge jump hard core or stay steady? mine jumps hard at idle
Old Apr 21, 2006 | 05:15 PM
nk2k2's Avatar
Default Re: fuel pressure regualtor questions (project_K)
sorry to thread jack, but can you put a fpr on a d15b2 motor, would it even be worth it?
Old Apr 21, 2006 | 05:21 PM
richboi's Avatar
Default Re: fuel pressure regualtor questions (4g4d)
im wonderin bou the same thing!...unless u runnin a whole **** load of mods in that motor
Old Apr 22, 2006 | 10:22 AM
nk2k2's Avatar
Default Re: fuel pressure regualtor questions (richboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richboi &raquo;</TD></TR><TR><TD CLASS="quote">im wonderin bou the same thing!...unless u runnin a whole **** load of mods in that motor</TD></TR></TABLE>
if your talking to me, well the only mod that i have is an intake so i dont think it could affect it that much.
Old Apr 22, 2006 | 12:10 PM
GSRCRXsi's Avatar
how is that setup doing anything? it doesnt look like the adjustable regualtor is even hooked up to the fuel. looks like you just T'd the vac line off the stock regulator? wtf?
Old Apr 23, 2006 | 02:35 AM
zenon8890's Avatar
can u tell me exactly how should i install it again, should i remove my old regulator?!
Old Apr 23, 2006 | 03:19 AM
STREETWERKZ's Avatar
Default Re: fuel pressure regualtor questions (GSRCRXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">how is that setup doing anything? it doesnt look like the adjustable regualtor is even hooked up to the fuel. looks like you just T'd the vac line off the stock regulator? wtf?</TD></TR></TABLE>
seriously.
ebay spawns ricers.
EDIT: now that i look at it, it looks like the fuel return hose is going to the second FPR. how is your fuel getting returned to the tank?
p.s. i dig the AEM injector wiring cover. bahahaha.
Old Apr 23, 2006 | 04:46 AM
zenon8890's Avatar
plz can u send me details of how exactly should it be installed, thanks
Old Apr 23, 2006 | 05:02 AM
si0385.'s Avatar
lol
http://www.c-speedracing.com/h...r.php
i cant see exactly what kind you have there but this should be the same idea its gota go in place of the old fpr not just t'eed off of the old one
Old Apr 23, 2006 | 05:51 AM
Autoworks's Avatar
Default Re: (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">Looks good to me, </TD></TR></TABLE>
That install is very WRONG, not even close. You can't install a regulator after a regulator...it does nothing. That FPR gauge has got to be reading some crazy ish.
That Ebay regulator should have come with an adaptor plate to eliminate the stock FPR.
Old Apr 23, 2006 | 07:00 AM
zenon8890's Avatar
yes it did have an adapter, so i should remove the old regulator and put an adapter instead
Old Apr 23, 2006 | 07:08 AM
Autoworks's Avatar
Default Re: (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">yes it did have an adapter, so i should remove the old regulator and put an adapter instead
correct
Old Apr 23, 2006 | 08:05 AM
zenon8890's Avatar
i just did, but it started to leak fuel from the adapter, the old regulater has a rubber seal, the adapter i have doesnt have it, i put my old regulator seal on the adapter but it went iside it and it kept leaking, i dont have the FPR rubber seal for it, what things i can do so it wont leak?!
Old Apr 23, 2006 | 08:49 AM
Autoworks's Avatar
Just use a bigger O ring. Take the one you have to the parts store or Home Depot and get one or a few that are larger. My O ring fit fine, but my reg. is also by NRG. The OE O ring is also too small for the AEM FPR, but once its tightened down it doesn't leak.
Old Apr 23, 2006 | 11:41 AM
zenon8890's Avatar
Default Re: (Autoworks)
my oem ring fits on the new fpr, but it goes deep in it, after i buy a new ring how much psi should i put?! i'm running a d15b vtec with pm6 ecu and headers and intake
Old Apr 23, 2006 | 11:43 AM
Autoworks's Avatar
35-38psi will be fine, the gains from a fpr w/o tune are negligeable
Old Apr 23, 2006 | 11:55 AM
zenon8890's Avatar
thanks man i'll be on it
Old May 3, 2006 | 08:18 AM
zenon8890's Avatar
i couldnt find any o-ring that fits the adapter, it leaks fuel, what other things i can do?!
Old May 3, 2006 | 10:25 AM
zenon8890's Avatar
bump
Old May 3, 2006 | 11:18 AM
zenon8890's Avatar
guys i guess someone can help, the situation is when i install the adapter on the fuel rail it leaks fuel, i used the o-ring from my old FPR its smaller, i cant find an o-ring, what should i do?
Old May 3, 2006 | 02:49 PM
HatchBox's Avatar
Skoobie no more...
..um buy another o ring from honda.
Since the old one is flatter due to age.
Old May 3, 2006 | 03:20 PM
vegaskurt's Avatar
Default Re: (HatchBox)
Go to a napa or meyers, they should have assortments of O rings.
BTW, the way you first pic of your setup had me on the floor screaming.
Old May 4, 2006 | 12:37 PM
zenon8890's Avatar
Default Re: (vegaskurt)
is it the setup or how i installed the FPR
