Camber kit? LCA? Toe? What do i replace to fix my wheel
need to get my tires standing up straight instead of pushed in because i dont want my tires worn down in like 5months. these are expensive tires but i dunno what to replace exactly.. im looking for what i need to replace to fix my problem and will also give me a better ride at the same time and look nice from the rear
^ ya know what i mean
Get a camber kit, or you can use washers, you might have to get longer bolts...but that depends on how many washers you will end up using.
Some negative camber is good. Just get a front camber kit and an alignment, cause toe KILLS tires. If you want a rear kit, just go with the washer trick. It's cheap and easy. Get it aligned with 0 toe all around. Toe, not camber destroys tires.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz »</TD></TR><TR><TD CLASS="quote">Some negative camber is good. Just get a front camber kit and an alignment, cause toe KILLS tires. If you want a rear kit, just go with the washer trick. It's cheap and easy. Get it aligned with 0 toe all around. Toe, not camber destroys tires.</TD></TR></TABLE>
for this comment!
for this comment!
You're having the same problem I'm having on my car. I'm just taking it in for alignment. Just figure out what height you're going to keep it at, then get the alignment done. Everytime you remove your suspension to raise or lower it the alignment should be done again. Interestingly, you also have the same setup as me: KYB AGX and ground controls with eibach springs, correct?
ok first off camber and toe does wear tires (caster doesnt). a little bit is ok but not a whole 3-4 degrees like that. from the looks of it you will need the kit in the front and rears. you could do that washer trick but that takes too much time. you're probably better off with the kit. its easier to adjust. just install it then bring it in for the alignment. they wont charge you extra for that adjustment as long as you've got a way to adjust it.
Modified by turbodegsi at 1:53 PM 4/12/2006
I dropped my car 1.5 inches and the alignment was messed up (I haven't done alignment since and that was in October), it's supposed to be a safety precaution to allign your car. Isn't it anymore than 1.5 inches needs a camber kit?
EDIT::
I called the auto shop about aligning my car, and this may not be true for all shops, but if you have a camber kit it's more expensive to get it aligned. I don't know why, but they quoted me $80 without camber kit and $100 with camber kit. So you might want to look into that
EDIT::
they're ripping you. ok tell them if it was a older ford with the bushings for camber would they charge extra for loosing the bolt and turning the bushing? i think it's bull they're hateing because it an import. tell them to eat it. stock or not it's still part of the alignment. here in mn we only charge from 39.99-69.99 front-69.99-100
for the 4 wheel alignment. keep in mind with hell of rust!!!!!!!!
Actually it was a shop called motorsports, they're an official honda/ acura repair shop. I've never known honda dealers/ official honda related companies to be cheap, so I guess that's expected.
Guest
Posts: n/a
Well i got 2 on both bolt holes on both sides in my rear, even though im not sure if my car is really 2" inches droped or 4". I dropped it about 2" while backn on the stock 13's, then when i threw on my good wheels that were 15's, it went back up so i dropped it another 2" to get it back to the height it originally was with the 13's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonracer84eg »</TD></TR><TR><TD CLASS="quote">what kinda tires are those?</TD></TR></TABLE>
http://www.tirerack.com/tires/...KDW+2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by central_driver »</TD></TR><TR><TD CLASS="quote">
http://www.tirerack.com/tires/...KDW+2</TD></TR></TABLE>
Those tires suck, from the reviews.
Raise your car, because it's WAY too low.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zseeanz »</TD></TR><TR><TD CLASS="quote">Some negative camber is good.</TD></TR></TABLE>
. . . but that is way too much for the rear. It's going to understeer like a pig. You always want less negative camber in the rear than in the front.
how much negative camber is good? I'm taking my car in for alignment and I'm wondering if neutral camber or some negative is better. Like how many degrees? Because I don't want enough to unevenly wear my tires. Planning to DD and maybe autox once in a while.
