question...car wont start b/c of somthin stupid?
ok so today i had to swap throttle bodys b/c the nipple one of the vacume hoses go onto was broken off and w/o that the car idles real low and smokes real bad...so i put a new one on but i had to switch all the crap like the throttle swith thing and the spring so i did that and put it all on and started it up but when you floored it, it acelerated real slow so i took it back off...messed with it, put it back on and now it wont start...so i switched everyting back to the old one and used a straw for that vacume and it stilll wont start...it'lll try to turn over but thats it....wont do enything....its gettin spark...battery is fine...its getting fuel....fuses are good. resseted the ecu....what the hell can the problem be?...everything is hooked up right...
it has gas, fuel pump works, its gettin spark, everything is pluged in right, fuses are all good...all i did was put a diffrent throttle body on...(same stock one) and now it wont start....when i put it on the first time it would start but when u were to put the peddal to the flore it would accelerate very slow and sound like crap...then i took it back off then put it back on and it wont start now...when i took it off the first time one of the hoses conected to the TB has fluid in it and now it doesnt...may that be the problem? help me out i have no idea what the hell is wrong with it and i need a car to drive
k24ej8
Sep 30, 2006 03:20 PM
chinese buffet
Jul 16, 2006 05:09 AM
