oil change questions..
Old Apr 5, 2002 | 09:29 AM
p0pe's Avatar
Default oil change questions..
Hey, I just got my car ~1.5 months ago and its time for a oil change.
The problem is that I didn't get an owner's manual with my car.
I've searched for specs on how many quarts it takes, etc. and how
to reset the "maintenance required" indicator but didn't come up with anything
specific to my 97 accord ex (4cyl). Can anyone fill me in on some of this? I can't
find jack .
[Modified by p0pe, 10:30 AM 4/5/2002]
Old Apr 5, 2002 | 09:31 AM
Accord94DX's Avatar
Default Re: oil change questions.. (p0pe)
4.5 quarts of 5w30. Fram Filter code: PH3593a but most peeps in here run OEM honda filters. To reset the maintence indicator, insert your key into the slot adjacent the Odometer trip reset button.
Old Apr 5, 2002 | 09:33 AM
p0pe's Avatar
Default Re: oil change questions.. (Accord94DX)
Thanks
Old Apr 5, 2002 | 10:00 AM
CD8's Avatar
CD8
i always only run 4 quarts. Oops!
[Modified by exaccord, 11:00 AM 4/5/2002]
Old Apr 5, 2002 | 10:11 AM
4doorH22's Avatar
My routine is to buy an OE filter and drain plug washer from the dealer, and then pick up a 6-pack of Mobil 1 from a cheap auto parts store.
Old Apr 5, 2002 | 11:00 AM
Kazmans94cord's Avatar
fram???? fram sucks!!! it doesnt filter well
Old Apr 5, 2002 | 11:01 AM
Default Re: oil change questions.. (exaccord)
i also run 4 quarts...and dave why do you buy a new drain plug each time?
Old Apr 5, 2002 | 11:02 AM
Accord94DX's Avatar
Default Re: oil change questions.. (kazmans94cord)
He means the drain plug crush washer. You're supposed to replace everytime.
Old Apr 5, 2002 | 11:07 AM
TypeSH's Avatar
I use 4.5 w/ a new filter. I let the oil sit and drail for a while, it still drips after 15-20 mins. So I just let it all drip out before filling it again. Try Bosch, STP, or Mobil 1 filters. Don't get the fram orange one.
Old Apr 5, 2002 | 11:12 AM
ok yeah i kinda skipped over the word washer...my bad yall
Old Apr 5, 2002 | 01:07 PM
4doorH22's Avatar
I asked a local dealer if I could save on a bulk purchase of oil filters. He said I could get a case of 30 filters. I was like "oh okay I'll take that." Then my friend was like "dude do you know how many years that will last?" I was like "oh yeah nevermind."
Old Apr 5, 2002 | 01:10 PM
SOHCArchangel's Avatar
Default Re: oil change questions.. (4doorH22)
LOL, well dude we could find a case of HAMP filters, and split the cost and filters between the three of us......
Old Apr 5, 2002 | 01:34 PM
Default Re: oil change questions.. (SOHCArchangel)
what are HAMP filters? ive never heard of those
Old Apr 5, 2002 | 03:28 PM
4doorH22's Avatar
http://www.inlinefour.com/honhamoilfil.html
Introducing Japan Honda's aftermarket line of automotive products..."HAMP Synergy". HAMP Synergy are aftermarket products designed by Honda and are a step up from the "Honda Original Parts" products. Not meant to compete with racing produts, however, these peices are quality. The HAMP filter can be used on any Honda, but was specifically designed for use in the Type-R and S series cars in mind. Features include a unique release valve that dynamically adjusts to the conditions within the filter to keep the oil flow and pressure constant. The HAMP oil filter will last longer and filter better than any of the oil filters currently on the market.
However, I think the USDM OE filters are just fine. But these HAMPs are pretty dope.
Old Apr 5, 2002 | 04:02 PM
smokin rubber's Avatar
very strange . I was just thinking about a group buy on filters. anybody know where we can set one up?
Old Apr 5, 2002 | 04:11 PM
Mike P.'s Avatar
25 Year Member
Default Re: oil change questions.. (smokin rubber)
One time Dave and I went to the local dealer and he almost bought a case of 30 filters.... The look on the guy behind the counter's face was priceless! "You mean to tell me you want 30 filters?"
Old Apr 5, 2002 | 06:18 PM
Accord94DX's Avatar
Default Re: oil change questions.. (Mike P.)
Whats the big deal? Me and my brother have a case and a half of filters between our 3 hondas.
Old Apr 5, 2002 | 06:26 PM
Mike P.'s Avatar
25 Year Member
Oh, it's a fockin' big deal! Buleedat!
Old Apr 5, 2002 | 06:28 PM
Accord94DX's Avatar
STOP TRIPPIN!!!!!
Old Apr 6, 2002 | 04:44 AM
Razor's Avatar
use 4.5 quarts and try to use the oem honda filter and oil pan washer from honda.
the oil pan bolt is 17 mm. drive the car around the neighborhood to warm up the oil so when you drain it, it flows out faster and more dirty oil gets drained. take off the oil cap on the engine before draining, this also allows the oil to drain out faster.
make sure the oil pan bolt and washer are tight when you put it back on, but don't over tighten it OR you'll overstrip it and its a pain in the *** buying a new oil pan. for the oil filter, hand tight it and get a filter wrench and turn it 1/4 clockwise.
Old Apr 6, 2002 | 12:24 PM
hey brian you wanna translate that for me? that would be fantastic...unless the quote is what it says...in that case nevermind them!
Old Apr 6, 2002 | 12:59 PM
CardDealer's Avatar
Banned
I buy the bulk package from honda all the time... 3 4th gens in the family. I feel like a mechanic at jiffy lube every 3 or 4 months.
Old Apr 7, 2002 | 03:13 PM
bmm89's Avatar
Default Re: oil change questions.. (schlit)
Same here, have 25% discount all the time at Airway honda(chicago) and i usually hook up all friends and relative with honda oem stuff along with the cars themselves.
Old Apr 7, 2002 | 03:16 PM
bmm89's Avatar
Default Re: oil change questions.. (bmm89)
Also, when buying the oem filters, be sure to get the crush washer, they SHOULD be taped to the top of each sealed filter... some dealers neglect to include the washer. And i usually run 4.5 qts but that's because i change it on an incline so a little more runs out.
o8EXLCoupe
Jun 3, 2008 06:30 AM
RDAYA0
22
Apr 25, 2008 03:11 PM
skafia
Nov 25, 2002 01:04 AM
shadowdawn
Jul 29, 2002 07:14 AM
