Oil change from HELL!
Old Jul 28, 2002 | 10:01 AM
shadowdawn's Avatar
Default Oil change from HELL!
Well yesterday while changing oil me and a friend ran into a real shitty problem.... the oil filter wouldn't come off.... needless to say 3 hours and lots of muscle and inventivness got it off, I wanted to yell at my friend because he tightened it last oil change which is why it wouldn't come off.... HAND TIGHTEN ONLY (according to helms)....
Anyway, he also bought regular 10w30 not synthetic and I was forced to use it. I had been running synth for 3-4 months now and just last night had to make the dratic change back to regular motor oil.... there is nothing detrimental about this is there?
Old Jul 28, 2002 | 10:07 AM
Smashback's Avatar
Default Re: Oil change from HELL! (shadowdawn)
You won't have any problems. If your filter gets stuck, get a long philips head screw driver and hammer it all the way (sideways) thru the filter. This will allow you to turn it and get it off. Messy, but it works.
Old Jul 28, 2002 | 10:15 AM
salt's Avatar
yeah, that happened to me while I was in a hurry to go somewhere.
I used sandpaper on the filter to get a better grip.
steve
Old Jul 28, 2002 | 10:30 AM
SIK IN DA HED's Avatar
New User
Default Re: Oil change from HELL! (salt)
ive had that problem before. i just jammed a flathead into it and pulled on the handle to twist it off. sanding it down didnt help much because it was leakin oil. i think using the regular 10w30 oil is alot better than synthetic IMO.
Old Jul 28, 2002 | 10:54 AM
zojirushi's Avatar
Default Re: Oil change from HELL! (dlplayboy)
u gotta use one of those oil filter caps. you can connect a socket wrench to it. gets the most stubborn oil filters out.
Old Jul 28, 2002 | 12:06 PM
filetofit
Guest
Posts: n/a
Default Re: Oil change from HELL! (zojirushi)
A big *** pair of channel lock pliers.
Old Jul 28, 2002 | 12:32 PM
Smashback's Avatar
I haven't found one that fits the Honda filter belive it or not! I've checked all the O'Reillys...
Old Jul 28, 2002 | 12:54 PM
JMinSi2000's Avatar
Default Re: Oil change from HELL! (mplex2000)
Check Autozone. I got one for my Civic there.
Old Jul 28, 2002 | 01:10 PM
Finest's Avatar
Default Re: Oil change from HELL! (JMinSi2000)
Am I the only one that uses an oil filter wrench? I handtighten as far as I can, then use the wrench to turn about another 1/2 turn. And it makes removing the filter later WAYY easier.
Old Jul 28, 2002 | 03:37 PM
InfamousRS's Avatar
Man, your not looking very hard! I got mine at Wal-Mart for $1.97
Old Jul 28, 2002 | 03:46 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Oil change from HELL! (InfamousRS)
yeah i use the filter wrench too. It's a piece of cake to take a filter off with one. It's like a clamp with the loose end attached to a handle so you can twist it one way and itll tighten down on the filter then you push it and it unscrews really easy. Hard to explain but it's a really simple design. theyre cheap.
Old Jul 28, 2002 | 04:31 PM
Mr. Vapor's Avatar
Default Re: Oil change from HELL! (PreIudeSI)
ironically i had the same problem....last bastard to do my GFs oil did it wrench tight, coudlnt get it off the damn block....
ran up to sears and got a craftsman universal oil filter wrench ($12.99)
this thing is sweet! saves you time and busted knuckles!
Old Jul 28, 2002 | 04:34 PM
B-Series Sol's Avatar
I heard once u use synthetic u can't go back, is that true?
Old Jul 28, 2002 | 04:43 PM
Etylorcen's Avatar
Default Re: Oil change from HELL! (B-Series Sol)
No its not true but you shouldnt be switching back and forth all the time. Last time I did my oil change I couldnt get my oil filter off and I coudlnt manage to hammer a screwdriver thru either...no damn room to swing so I just drilled a hole then used a screw driver. Damn oem filters are strong. When I had to do this on my friends car w/ his fram filter the screwdriver went thru pretty easy.
Old Jul 28, 2002 | 04:46 PM
Kamin's Avatar
you know they make an oil filter wrench guys.
Old Jul 28, 2002 | 04:51 PM
shadowdawn's Avatar
Actually thats what killed it, it stripped and all it did was slip on the filter...... but whatever its just bad luck
Old Jul 28, 2002 | 06:10 PM
BoostedH23a1's Avatar
snap on, mac tools, S&K, stanley, matco all make oil fiter taker offer tools. look like a handel and a metal circle strap. you can probably get one at advance auto or someplace like that too
Old Jul 28, 2002 | 07:24 PM
FBP Si 2000's Avatar
Default Re: Oil change from HELL! (Prelude_RCR)
Old Jul 28, 2002 | 07:27 PM
paulzy's Avatar
Default Re: Oil change from HELL! (FBP Si 2000)
I use the screwdriver thing too on stubborn filters
Old Jul 28, 2002 | 10:01 PM
Flamenco-T's Avatar
Default Re: Oil change from HELL! (Slow_ass_4dr)
yes the almighty screw driver....
and shitload of oil running down you arms....
Old Jul 28, 2002 | 10:05 PM
rjardy's Avatar
I like this idea, its messy but who cares. and its cheaper than buying an oil filter wrench! Its not like you are going to use the filter again anyhow!
Rob
Old Jul 29, 2002 | 06:27 AM
Doodoo's Avatar
Default Re: Oil change from HELL! (rjardy)
I used one of those rubber jar opener things with the grip on it. Worked great, this time. CRX+B-series=no fun oil changes.
Old Jul 29, 2002 | 07:14 AM
CovertFI's Avatar
Default Re: Oil change from HELL! (Doodoo)
i take my car to walmart every time to change my oil. i figure they have insurance if some thing goes wrong, i dont.
RDAYA0
22
Apr 25, 2008 03:11 PM
coot_er
Aug 23, 2006 07:23 PM
vtech_tuner
Aug 3, 2005 06:27 PM
mr poo
Aug 4, 2003 04:38 PM
GGSSRR
Sep 6, 2001 09:10 PM
