"rear washer trick" for the camber kit!?
can some one explain to me how to do the "rear washer trick" for the camber kit on a eg i have ingalls camberss i bout the screws n washers from home depot but now i need how how to do the trick please help some1
the 2 i believe its 12s or 14s on the back top.(u see it when tire is removed) unscrew those. put washers and the longer screws thats it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Search dumbass, this is covered 9 times a day. It's also on the Omnipower website.</TD></TR></TABLE>
nice, glad to see these fools tryin to help you and callin you names, stay classy
take your rear wheels off, locate the upper control arm. It connects to the frame with two bolt. That the bolts out and get slightly longer and by slightly like maybe a 1/4" and some washers. Washer go between the frame upper control arm. done
My JDM EJ8
Mar 16, 2008 12:24 PM
