how to disable the beep when the key is in
Old Apr 8, 2006 | 01:11 PM
wheelmanbg's Avatar
Default how to disable the beep when the key is in
Does anyone know how to disable the beeping when the key is in and the door is open?
Old Apr 8, 2006 | 01:18 PM
EM199dcs's Avatar
Default Re: how to disable the beep when the key is in (wheelmanbg)
Yeah usually theres a piece to behind you and to the left where the door is if your sitting in the car. Its held on by a phillips screw. Mine is black. Take it out and no more beep.
Old Apr 8, 2006 | 01:29 PM
Out of every
beware though if you have an alarm. your alarm wont enable if that is not connected
Old Apr 8, 2006 | 01:31 PM
wheelmanbg's Avatar
Yeah i'd rather pull out the beeper than the door switch because i do have an alarm...
Old Apr 8, 2006 | 01:42 PM
Nevaeh Speed's Avatar
The easy way is to remove the cover over the wiper arm/ turn signal arm(steering column cover). Now where your ignition is the will be a little black looking box connected there. It's held on by a small Phillips. Once you remove that screw let it just hang in there, you'll see the little push button it has. And thats what keeps the beeping going when the key is in....
This is for eg's and ef's... I'm pretty sure is the same with ek's. Good luck.
Old Apr 8, 2006 | 01:51 PM
wheelmanbg's Avatar
Default Re: (Nevaeh Speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nevaeh Speed &raquo;</TD></TR><TR><TD CLASS="quote">The easy way is to remove the cover over the wiper arm/ turn signal arm(steering column cover). Now where your ignition is the will be a little black looking box connected there. It's held on by a small Phillips. Once you remove that screw let it just hang in there, you'll see the little push button it has. And thats what keeps the beeping going when the key is in....
This is for eg's and ef's... I'm pretty sure is the same with ek's. Good luck.</TD></TR></TABLE>
You are GOOD! That worked like a charm. I just took it off. Now I can work on my car and listen to music without that extremely annoying beep
Thanks
Old Apr 8, 2006 | 02:05 PM
tallyturbo's Avatar
Default Re: (wheelmanbg)
and just to clarify your alarm still works good
Old Apr 8, 2006 | 02:16 PM
tallyturbo's Avatar
i just took my colum thing off and i dont know where that box thing is
Old Apr 8, 2006 | 02:34 PM
kodou's Avatar
Great. i'm gonna try this on my ek. hope it works
Old Apr 8, 2006 | 03:18 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks</TD></TR></TABLE>
lol or you can just remove the red 7.5 fuse that controls the interior light which also control the annoying beep..
on the eg's it will be one of the red 7.5 red fuses on the bottom part of the fuse box in the middle (bottom middle red 7.5 fuse)
on the ek's it will be #43 7.5 fuse on the engine fuse box.
:i kinda like the beep:
Old Apr 8, 2006 | 04:08 PM
tallyturbo's Avatar
Default Re: (cxSHOE)
i did what the said in an earlier post. hey it works. and my alarm still works. that something good to know. also this would be a good trick to play on my brother. what i plan on doing is taking his and duck taping it closed so no matter what he does it will be on. he will have no idea how to fix it unless he comes on here and sees my post.
Old Apr 8, 2006 | 05:34 PM
wheelmanbg's Avatar
Default Re: (tallyturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo &raquo;</TD></TR><TR><TD CLASS="quote">i did what the said in an earlier post. hey it works. and my alarm still works. that something good to know. also this would be a good trick to play on my brother. what i plan on doing is taking his and duck taping it closed so no matter what he does it will be on. he will have no idea how to fix it unless he comes on here and sees my post. </TD></TR></TABLE>
That's a good prank cus It would drive me insane! But yeah my alarm works great and i already had the steering column cover off cus i was hooking up my remote start so it was really simple
Old Apr 8, 2006 | 06:15 PM
kodou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg &raquo;</TD></TR><TR><TD CLASS="quote"> Now where your ignition is the will be a little black looking box connected there. It's held on by a small Phillips. </TD></TR></TABLE>
the only "black box" in my ek is the one containing the wiper controls. (just out of the picture top center) i don't see anything else but the ignition.
Old Apr 8, 2006 | 10:55 PM
SiYouLater's Avatar
Default Re: (kodou)
I have an 94 civic and I didn't see a black box.
Old Apr 8, 2006 | 11:06 PM
Filliam H. Muffman's Avatar
Default Re: (99FBPSi)
Now, you all realize, he can just turn his key to the second click, and the beeping stops after 6 beeps or so. ( the beeps on the second click are longer.)
Old Apr 9, 2006 | 03:56 AM
LaOstha's Avatar
Default Re: (Filliam H. Muffman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Filliam H. Muffman &raquo;</TD></TR><TR><TD CLASS="quote">Now, you all realize, he can just turn his key to the second click, and the beeping stops after 6 beeps or so. ( the beeps on the second click are longer.)</TD></TR></TABLE>
Yea but that turns on everything and that drains the battery alot faster
Old Apr 9, 2006 | 05:29 AM
tallyturbo's Avatar
Default Re: (LaOstha)
you will find it on the under sid of the ignition. i didnt see a black box so what i did was look for a small gold phillips head screw and undid it.
Old Apr 9, 2006 | 07:41 AM
wheelmanbg's Avatar
Default Re: (kodou)
just look by your key hole! There are two wires wrapped in black plastic that go into the back side of where your key goes. You can just cut them off or take out the little module that they go into which is held on by one small gold phillips srcrew
I took mine off and then cut the wires so it's not just hanging there.
Old Apr 9, 2006 | 07:34 PM
SiYouLater's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg &raquo;</TD></TR><TR><TD CLASS="quote">just look by your key hole! There are two wires wrapped in black plastic that go into the back side of where your key goes. You can just cut them off or take out the little module that they go into which is held on by one small gold phillips srcrew
I took mine off and then cut the wires so it's not just hanging there.</TD></TR></TABLE>
Ok I did see those wires. Gonna try it later.
OmgDelSol
Audio / Security / Video
Jan 26, 2012 07:54 PM
jdmer329
Oct 10, 2010 08:35 AM
Mualphapiper
Mar 17, 2006 01:24 PM
Integra Integra
Jan 5, 2006 10:54 AM
skafia
May 7, 2002 09:28 PM
