PRoblem with how install Lower arm rear..
Old Apr 8, 2006 | 11:25 AM
Walterronny's Avatar
Default PRoblem with how install Lower arm rear..
hi! today i tried to install the omni lower arm rear.. but i have a problem.. with brake line fluid and with the strut bar lower ..
i made a pics..
here a pic about brake line fluid..
if a put the lower arm onmi , how or where do i put this line? (the lower arm OEM have a holes that support this line..
this pic is the problem that i have with the strut bar lower OEM.
the lower arm rear OEM, has a support for the strut bar lower OEM , but the lower arm rear onmi doesnt has it..
the question is, how can i to install it? i need a new strut bar lower rear? which¿?
thanks
Old Apr 8, 2006 | 12:07 PM
spoonracer84eg's Avatar
Default Re: PRoblem with how install Lower arm rear.. (Walterronny)
hmm. Wish I could help you but you obviously dont have an eg. Installing my omni rear lower control arms was a matter of 3 bolts on each arm. The line would probably be ok hanging or maybe drill a hole on the arm?
Old Apr 8, 2006 | 12:12 PM
ZipTieGUy's Avatar
for the line just zip tie it or something
for that "strut bar" is realy your sway bar, it goes into the hole in the middle of your omni lca, the hole without bushings
Old Apr 8, 2006 | 12:33 PM
xerox445's Avatar
Default Re: (ZipTieGuy)
You really dont know anything about your car do you....
Thats the ABS Wheel speed sensor wire.....
Go to a mechanic
Old Apr 8, 2006 | 12:44 PM
ok, but it hole doesnt has a thread for the screw.
xerox445 , sorry, you have reason , i dont know all about my car.. but i want to know almost all about my car...
if i remove the sway bar and i put a strut lower bar rear? are they seems?
for example (it's of other car..)
help me please..
Old Apr 8, 2006 | 12:49 PM
xerox445's Avatar
Default Re: (Walterronny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Walterronny &raquo;</TD></TR><TR><TD CLASS="quote">ok, but it hole doesnt has a thread for the screw.
help me please..
I repeat go to a mechanic that speaks your language....
If your trying to say, can you take your rear sway bar off and put a lower strut bar on to replace it, will it be the same....uh no. Don't take the sway bar off...
Old Apr 8, 2006 | 12:55 PM
. ok. thank you. and sorry if my bad english bother you, and yes, i tried to say that.
Old Apr 8, 2006 | 04:52 PM
94eg!'s Avatar
#1 Super Guy
Loved
You will need longer bolts with nuts to attach your existing sway bar to those new LCAs.
As for the ABS sensor wires (not fluid lines), you could just zip tie them to the new LCAs. If you do that, you should check on them every once and while to make sure everything is good.
Old Apr 8, 2006 | 11:59 PM
Default Re: (94eg!)
ey brother, thank very much... i appreciate it..
Old Apr 9, 2006 | 06:20 AM
EG2Driver's Avatar
yea make sure you check because if one wire is cut on ur ABS line, it'll affect ur whole sistem and may induce certain wheels locking up and certain that would not and you could eat it. Get metal zip ties, and i would also get a loom to put the wires in as to not damage them. Good luck.
Old Apr 12, 2006 | 12:58 PM
Default Re: (EG2driver)
ok thank you
Old Apr 12, 2006 | 01:01 PM
GarageAlchemist
Guest
Posts: n/a
lol, dood its 3 bolts, takes 10 mins to install an lca at best...
if your having this much trouble, ummm.. i dunno man, find a new hobby
Old Apr 12, 2006 | 01:15 PM
Default Re: (GarageAlchemist)
haha i know man . the only problem is if i'll can to put the sway bar on LCA but ok, i'll try do it.. (it's easy but like repeat the only problem is to fit the sway bar on LCA) :
joethejoeman
Feb 22, 2007 10:00 AM
BlueRex1020
Oct 8, 2006 12:50 PM
dasistheone
Mar 3, 2006 05:45 PM
ctownintegra
Feb 27, 2005 08:37 AM
