TransMission Help?
Old Apr 8, 2006 | 10:56 AM
turbocivic0618
Guest
Posts: n/a
Default TransMission Help?
Hey, when the car is started it makes a noise but when i push in the clutch it goes away, and when im driving when its in a gear it makes a noise till i take it out of gear. I changed my last transmission because it went bad and wouldnt drive no more. I replaced the wheel bearing... i did a auto to manual conversion but i never changed the ECU... This is the second trans i changed on this car. Could the problem be because i didnt change the auto ECU or just bad trans? Does it sound like a wheel bearing? What trans oil is best to use? This is a turbo d16y7 for the motor and 92 HB.
Thanks, for any help
pmldeckman@aol.com
Old Apr 8, 2006 | 11:06 AM
YeuEmMaiMai's Avatar
Default Re: TransMission Help? (turbocivic0618)
is this for an accord?
Old Apr 8, 2006 | 11:09 AM
turbocivic0618
Guest
Posts: n/a
Default Re: TransMission Help? (YeuEmMaiMai)
Its for a 92 civic Hatchback with d16y7
Old Apr 8, 2006 | 11:24 AM
there is a civic forum here and you might get better help there since you have a Civic. Usually when installing a manual trans into an auto car you should change the ECU to the manual one...........or make the nessescary changes to the auto one....
Old Apr 8, 2006 | 08:04 PM
jaysome01's Avatar
I actually have this same problem with my 94 accord EX /5SPD. Anyone have a clue on whats going on?
Old Apr 9, 2006 | 04:52 PM
jaysome01's Avatar
When the car is started it makes a noise but when i push in the clutch it goes away, and when im driving when its in a gear it makes a noise till i take it out of gear. I changed my clutch because it went bad and wouldnt drive no more. Anyone have any insight on what could be causing the sound? Do I need a new tranny? Flywheel?
Old Apr 9, 2006 | 05:52 PM
accord-pro's Avatar
it sounds like the mainshaft bearing is ( are ) noisy,,,.. what kind of tranny fluid is in it ??
the ecu has nothing to do with the noise .. it is internal tranny noise//
Old Apr 9, 2006 | 11:21 PM
jaysome01's Avatar
Default Re: TransMission Help? (accord-pro)
could have sworn it was actually engine oil 10w-30.. or correct me if im wrong. it was a few years ago when I changed the clutch.. Do you recommend any transmission fluid? The car is getting a suspension change right now and its on jacks. I might as well do the transmission fluid change if I have to..
Old Apr 12, 2006 | 10:40 AM
turbocivic0618
Guest
Posts: n/a
what kind of trans oil you use? i bought the input shaft bearing and waiting for it to come in from dealer. Im just going to replace it thanks..
Old Apr 12, 2006 | 10:43 AM
turbocivic0618
Guest
Posts: n/a
I know the ecu isnt making the noise.... I had another tranny that went bad and finally died that acted the same way this one is. I was just wondering since the ecu is still auto would that caused any problems with the trannys? just curious, because i forgot to take out the manual ecu from the doner car.
Old Apr 12, 2006 | 09:35 PM
jaysome01's Avatar
well my car is still undergoing a suspension overhaul... I drained out the tranmission fluid... when i drained out the fluid there was about 1 quart... I think thats bad.. I should be good now.. I put 3 quarts of castrol syntec blend 10w - 30.. when im done with the suspension Ill know if that helped.. crossing my fingers...
Old Apr 27, 2006 | 04:04 PM
jaysome01's Avatar
Default Re: TransMission Help? (jaysome01)
FINALLY MY CAR IS BACK ON THE ROAD.. EXHAUST IS ON.. NEW DROP IS ON.. CARS LOOKING DECENT... MY DAMN TRANSMISSION IS NOW ACTING UP EVEN MORE.. OK SAME WITH THE SOUNDS FROM PREVIOUS REPONSES BUT NOW WHEN I FLOOR IT ON 3RD, 4TH, OR 5TH.. IT DOESNT GO ANYWHERE... IT JUST REV'S.. WHATS WEIRD IS THAT I CHANGE MY CLUCH A WHILE AGO.. ITS HARD TO BELIEVE ITS MY CLUTCH.. ANYONE HAVE ANY INSIGHT?? OH, I WAS THINKING.. IM GOING TO DO A H22 SWAP (MAYBE WITHIN A YEAR).. I GOTTA SAVE FIRST.. BUT I NEED MY CAR BACK ON THE ROAD RUNNING FINE AGAIN..
CAN I PUT A 94 - 95 PRELUDE H22 TRANNY ON A F22B1 STOCK BLOCK???
TELL ME WHAT ANYONE THINKS...
Old Apr 27, 2006 | 04:32 PM
XiOus271's Avatar
Well, for tranny fluid, pretty much everyone around here will tell you to use genuine Honda tranny fluid. And yes, I am pretty sure that Prelude transmission will bolt up.
Old Apr 27, 2006 | 04:41 PM
jaysome01's Avatar
Default Re: (XiOus271)
COULD YOU RECOMMEND A TRANNY??? WHAT BOUT LSD? WOULD IT BE WORTH IT IF IM GOING TO ENGINE SWAP IN THE FURTURE?
Old Apr 27, 2006 | 05:11 PM
XiOus271's Avatar
Default Re: (jaysome01)
It depends on what you want to do with your car. If you plan on turbo charging it, the H22 tranny is great, if not, the F22 or F23 tranny should be fine. As far as engine swaps, I would recommend a complete change over to an h22 + tranny with a factory LSD... that should do the trick for a bit. I don't know much about LSDs but the name of Quaife always pops up, so it s probably a decent one.
Old Apr 27, 2006 | 05:47 PM
manual trans uses honda MTF or GM syncro mesh or 10w30 oil
Old Apr 27, 2006 | 05:58 PM
jaysome01's Avatar
IM NOT SURE OF GOING BOOST BUT I WANT TO GO ALL H22 EVENTUALLY.. I GUESS I WILL DO MORE RESEARCH ON IT.. I DEFINATELY NEED A NEW TRANNY SO IF EVERYONE SAYS I CAN GET THE H22A TRANNY ON THE F22B1 BLOCK THEN ILL DO IT... SAVES ME FROM BUYING THE TRANNY LATER ON...
Old Apr 27, 2006 | 05:59 PM
jaysome01's Avatar
Default Re: (YeuEmMaiMai)
I THRU IN CASTROL 10W-30 SYTHETIC BLEND.. I SAW IT SOMEWHERE ON A FORUM TO USE IT.. DO YOU RECOMMEND CHANGING IT TO MTF FROM HONDA?? MAYBE THAT WOULD HELP??
Old Apr 28, 2006 | 11:39 PM
hondafam's Avatar
hey i have the same exact problem, when start my car and i take my foot off of the clutch it makes really bad grinding noises and i can't seem to figure out if its my clutch or do i need a new tranny?.. some times i can't even shift into gears. but my car isn't working and i just wanted to know if its my tranny or clutch thats the problem?..... please help
Old Apr 29, 2006 | 01:29 AM
iam7head's Avatar
Default Re: TransMission Help? (hondafam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafam &raquo;</TD></TR><TR><TD CLASS="quote">hey i have the same exact problem, when start my car and i take my foot off of the clutch it makes really bad grinding noises and i can't seem to figure out if its my clutch or do i need a new tranny?.. some times i can't even shift into gears. but my car isn't working and i just wanted to know if its my tranny or clutch thats the problem?..... please help</TD></TR></TABLE>
check if there's any freeway, Throw out bearing probably is toasted.
10w30 is the grade honda manual juice is using, the oem stuff have more wear/friction addictive to it and that's about it.
just to make sure, did you put 10w30/mtf into your clutch? because you need to use brake fluid for that. and you need to bleed the bad boy
Old Apr 29, 2006 | 03:50 AM
AccordEX1991's Avatar
Default Re: TransMission Help? (iam7head)
This might help you on the rattling noises.
https://honda-tech.com/zerothread?id=1499813
Old Apr 29, 2006 | 07:05 AM
johnwiltfongjr's Avatar
Default Re: TransMission Help? (AccordEX1991)
I have some noise when I drive as well...sounds like a kitten purring....It only happens when I am in gear and accellerating. When I push the clutch, it goes away. The performance isnt hurt and when the time comes, I will repair the tranny if need be. I am in the middle of a Honda automatic rebuild right now so I would think the manual rebuild would be a tad bit easier. I have never done one and it doesnt seem to be that hard but finding the time to get it done with 3 kids is difficult.
Old Apr 30, 2006 | 09:01 PM
jaysome01's Avatar
na yeah.. i used brake fluid for my clutch..
Whats weird is that I was just doing my brake bleeding today cuz it needed it. And i noticed something... with the car jacked up and the wheels off... the front right (passenger) side is still spinning.. when i press the clutch, the wheel stops spinning.. obviously somethings gotta be wrong.. seems like the clutch is still hitting even tho its not engaged into gear... weird..
Old May 1, 2006 | 10:05 PM
hondafam's Avatar
hey (iam7head) your tell'n me that it might not be my clutch but the bearing in the tranny?... i did use brake fluid for my clutch but i dunt get wuh chu mean by bleeding it?... please help
-thanks
Old May 1, 2006 | 10:14 PM
hondafam's Avatar
well if it is my tranny can i take it out straight from the hood or do i need and engine lift to do the job?
