WHAT ECU IS THIS?!
Old Apr 8, 2006 | 10:34 AM
JDM B16A's Avatar
Default WHAT ECU IS THIS?!
I have a JDM B16A FIRST GEN in an EM1. I want to know what kind of ECU THIS IS. The previous owner lable the ECU with a MARKER " 92-95 DEL SOL 5 spd". I have the feeling this ECU is chipped.... and I don't know if its the ECU or something else but my EM1 eat gas like a V6! PLEASE ALL YOU ECU PROS OUT THER HELP!
This look like the aftermarket CHIP
Old Apr 8, 2006 | 10:37 AM
BlueIntegraBoy's Avatar
Default Re: WHAT ECU IS THIS?! (JDM B16A)
Most likely a P28
Old Apr 8, 2006 | 10:40 AM
SVOboy's Avatar
Well, it's chipped and has vtec, prolly chipped like a p28 then. Throwing any codes?
Old Apr 8, 2006 | 11:06 AM
JDM B16A's Avatar
It has Vtec. And my Vtec engage at 5.9 RPM and I redline around 8.7
Old Apr 8, 2006 | 11:16 AM
Default Re: (JDM B16A)
Whoa, that's a late crossover. Stock B16 crossover is at 5500 rpms. Well, can't tell the ECU based off chipping specs. But the ECU could also be a P30.
Old Apr 8, 2006 | 11:18 AM
SVOboy's Avatar
Get a custom chip for it, about 20 bucks shipped, no problems then. The person could also read what's on the current chip and tell you what it is.
Old Apr 8, 2006 | 03:00 PM
JDM B16A's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Whoa, that's a late crossover. Stock B16 crossover is at 5500 rpms. Well, can't tell the ECU based off chipping specs. But the ECU could also be a P30.</TD></TR></TABLE>
Not really, alot of fully built motor crack vtec at 8.5 and reline at around 11.5. Its all in the dyno tune'n. Some vtec are more effective at higher RPMs.
Old Apr 8, 2006 | 03:08 PM
AntF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM B16A &raquo;</TD></TR><TR><TD CLASS="quote">Not really, alot of fully built motor crack vtec at 8.5 and reline at around 11.5. Its all in the dyno tune'n. Some vtec are more effective at higher RPMs.</TD></TR></TABLE>
But your motor isn't going anywhere near 11.5k, making that irrelevant to your situation. SVOboy has the right idea.
Old Apr 9, 2006 | 02:51 PM
JDM B16A's Avatar
yea, guess i'll give that a shot. Don't want my motor eating up gas for nothing.
Old Apr 9, 2006 | 02:54 PM
SVOboy's Avatar
If you wanna send it over here I'll give you a free read on it.
Old Apr 9, 2006 | 02:58 PM
RACEPAK's Avatar
Default Re: Shakalaka
maby you should try at:
http://www.pgmfi.org
Old Apr 9, 2006 | 03:01 PM
SVOboy's Avatar
Yeah, but he'd have to buy a chip burner to read it himself. pgmfi.org is the beast though.
Old Apr 9, 2006 | 03:06 PM
eg64u's Avatar
lmao if its near stock build your sohc ( if its sohc) wont do chit past 7500 if your lucky, haha wow stock sohcs suck *****.
Old Apr 9, 2006 | 03:47 PM
eXcelonTypeR's Avatar
Default Re: (eg64u)
He said it was a B16.... doesnt pgmfi have pics on identifying ECUs???
Old Apr 9, 2006 | 03:51 PM
SVOboy's Avatar
Well if it's chipped you can't just look at it.
Old Apr 9, 2006 | 06:38 PM
JDM B16A's Avatar
Default Re: (eXcelonTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg64u &raquo;</TD></TR><TR><TD CLASS="quote">lmao if its near stock build your sohc ( if its sohc) wont do chit past 7500 if your lucky, haha wow stock sohcs suck *****.</TD></TR></TABLE>
What in god's name are you talking about? Do you know anything aobut B16? And where did SOHC came from?
Old Apr 9, 2006 | 06:51 PM
Relic1's Avatar
looks to be a converted P06 to me.
hopefully you didn't expose the ROM enough to erase it by removing the sticker/cover like this...
Old Apr 9, 2006 | 06:53 PM
SVOboy's Avatar
The rom won't erase for hours, I've tried it, damn ***** in full sunlight for a day. It looks like a auto to manual p28 to me.
Old Apr 9, 2006 | 06:55 PM
Relic1's Avatar
it's auto-manual conversion for sure. But I thought 02D011F0-1500 P28s came with twin 5050s not a single 5151.
Old Apr 9, 2006 | 07:12 PM
SVOboy's Avatar
I dunno, but it doesn;t look like d11 or the 8 way resistor is soldered in.
Old Apr 9, 2006 | 07:21 PM
JDM B16A's Avatar
Still no clue what that ECU is or where it came from?
Old Apr 9, 2006 | 07:25 PM
Relic1's Avatar
hard to say about D11, not a very good pic.... wait this doesn't matter. If VTEC works and you don't have a solid CEL, it's what's in the EEPROM that matters.
Unfortunately it's soldered in. nothing a little time with a soldering iron will not solve but not as easy as it should be.
Old Apr 9, 2006 | 07:30 PM
SVOboy's Avatar
Haha, ****, didn't even notice it was soldered in, what a buttface.
Old Apr 9, 2006 | 07:51 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Haha, ****, didn't even notice it was soldered in, what a buttface.</TD></TR></TABLE>
personally I'd love to know what WOP means...
JDM B16A: your original question... it's obviously a converted ECU of some kind. What it was originially doesn't matter any more. The program in the EEPROM is what tells the ECU what to do and how to run your engine.
If you really want to know, have someone carefully remove the EEPROM for you with a soldering iron and read it with a burner/reader.
Old Apr 9, 2006 | 08:49 PM
Jim Truett's Avatar
Default Re: (Relic1)
That ECU started life as a P06-A52. Automatic P06 '94 or '95 model year.
