accord 93
Hi all,
I have a 93 honda accord EX with 157,000 miles.
Car starts fine but as soon as it really warms up, it would not take gas anymore. I have to remove my foot off the gas pedal in order for the car to go.
Any idea what it could be?
thanks
thanks
yes. I won't take gas anymore. Sometimes, the whole exhaust system start shaking when it stop taking gas.
Do you think the catalytic converter is blocked?
Is so, how do I check it?
If I remove it, Is there a way to check it?
I know for fact, nothing is loosing inside of it?
thanks,
thanks,
this is what you do:
1. pull the motor
2. run it over with a MACK truck
3. take a **** on it!
then spend cash to get a new or re-built motor, and start fresh, do things the right way!!
1. pull the motor
If you suspect a faulty cat. conv., loosen the nuts that attach your A-pipe at the cat conv. several turns so that you have a major exhaust leak. Then run the car and see if it has good power. If it does then you can remove the rest of the system and inspect the cat for blockage. The other simpler method is to connect a vacuum gauge the engine and see what the reading does as the engine starts to die.
*It sounds like your Ignition coil may be the problem!
hgreene1997
Oct 29, 2023 11:29 AM
project93accord
Feb 9, 2006 08:12 PM
