valve lash on d15b vtec?
Old Apr 8, 2006 | 08:27 AM
cr-x-91's Avatar
Default valve lash on d15b vtec?
whats the lashing specs on intake and exhaust. my question is this, does the car need to be warm or cold, whats the specs, and if u have any pics of how to. havent done one in long time and just wanted to know for suire b4 i do it.
thanx in advance.
Old Apr 8, 2006 | 08:40 AM
Ross 2.0's Avatar
In a Junkyard near you.
The valve lash is printed on the sticker under your hood. The engine should be as cool as pissible but Honda reccomends under 100 degrees.
The only way to propperly adjust them is to turn the crank 180 degrees 4 times and at each stop adjust the next cylinder. and of course you remember the slight drag rule and all. (if not just do a search)
Old Apr 8, 2006 | 08:43 AM
DestructoEH's Avatar
Default Re: valve lash on d15b vtec? (cr-x-91)
I came across this a while back and wrote it down...
intake (.007-.009) - exhaust (.009-.011) (same as D16Z6)
Also, you want to do it when the motor is cold. You might want to check out this thread for a how-to: https://honda-tech.com/zerothread?id=1305086 . Good luck.
davidhurt69
K Series
Feb 23, 2014 08:50 AM
wagon-r
Jun 11, 2013 09:32 AM
obuhmyuh
Apr 21, 2008 02:32 PM
96tegsr
Nov 22, 2005 11:07 AM
slow hatch
Mar 5, 2003 04:58 PM
