installing short throw shifter
Old Apr 8, 2006 | 07:44 AM
msinsky14's Avatar
Default installing short throw shifter
i have a 1995 civic hatch, i just got a brand new B&M short throw shifter drom a friend who sold hid car and didn't install it yet.........but my question is, does the car actually have to be jacked up to be installed, because I heard you just have to get to the boot, and I'm not sure exactly where that is.........any help would be appreciated
Old Apr 8, 2006 | 08:23 AM
strtciv93's Avatar
yes you have to have the car jacked up to install it. you have to unbolt parts of the shift linkage and other bolts that actually hold the shifter in place to the bottom of the car. wherever you heard that you just have to get to the boot, is wrong. there is a short shifter writeup somewhere, its really easy and doesnt take long at all.
Old Apr 8, 2006 | 08:31 AM
msinsky14's Avatar
Default Re: (strtciv93)
thanks, do you have the link to the write-up, but im gonna search anyways
Old Apr 8, 2006 | 01:29 PM
EM199dcs's Avatar
Default Re: installing short throw shifter (msinsky14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by msinsky14 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 1995 civic hatch, i just got a brand new B&M short throw shifter drom a friend who sold hid car and didn't install it yet.........but my question is, does the car actually have to be jacked up to be installed, because I heard you just have to get to the boot, and I'm not sure exactly where that is.........any help would be appreciated</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1007935
Thats a thread to a really good write up.
Old Apr 8, 2006 | 01:43 PM
james111's Avatar
yes u need to get under it....
10m and 12mm socket short
rachet long extension
take the shifter **** off
jack the car up
the exhaust rubber hangers near the shifter need to be pushed forward to give some slack
remove the 2 12mm nuts holding the flat mount on the right
remove the 12mm bolt off the bottom of the shifter.
remove the 10mm nuts attaching the shifter plate to the shifter rail
u will need a new shifter kit may be in the kit with theb/m if not buy energy suspension kit....
pull shifter down
replace the shifter boot kit and reverse process.
if your on the ground expect it to take 1 hour your first time.
bomber19
Sep 24, 2007 03:56 PM
ProjectCD5
Feb 21, 2006 11:55 PM
superbeastcrx
Sep 13, 2005 06:09 AM
krisjk2
Aug 16, 2005 05:52 PM
^LORTA^RACING
25
Mar 12, 2005 08:31 AM
