Stock Engine Destroyment?
Old Apr 7, 2006 | 06:52 PM
aXhatch's Avatar
Default Stock Engine Destroyment?
Hey all. Ive done a few swaps, am sitting here waiting for my obd0 b16a to get here. But I dont know how I want to destroy my motor. I took coolant/oil out of my last one and rev'd it at limit until the pistons melted. But what should I do now? anyone have a fun sugestion?
Its a crap motor. D15b(7!!!??!) literally the D15B7 from usdm dx in 92-95 with blown headgasket, piston/rings are fried, so its not worht trying to sell. I thought of this
Olive oil
Valve lapping solvent/solution (stuff for finnishin/cleanign valves.)
make about an ounce of it and put it in my oil Would be fun because the gritty valve lapping stuff would clog oil passages and KILL my bearings, and if it was ever rebuilt it would die instantly again. But im ripping it apart and selling the CLEAN aluminum for $2.00/lbs. so im nto worried about that. i think it would be cool to see how that happened.
Any ideas?
keep in mind Im just having fun, I dont wanna strap TNT to it or the last of my c4. I just want it simple and fast.
Old Apr 7, 2006 | 07:23 PM
dohc_profile's Avatar
spray anything you can find thats flammable as hell into an open throttle! be careful you dont hurt yourself tho.. rig something up to do that. and find an open road you can expletive aorund on....home made NOS! lol and fill your head with water. makes lots of steam! lol
Old Apr 7, 2006 | 07:30 PM
aXhatch's Avatar
Default Re: (dseries_ef)
yea there a funny vid of some guys destroying a d15b7 in there EG. burnouts non stop, water instead of oil. the thing goes on for like 10 mins. dies, then a few seconds later they start it up again. it is one the the coolest things around.
I dunno about the flammable thing....as u stated its a bit dangerous. But maybe some Ether (starter fluid) could be rigged up...push a small lever and it hits the spray nozzle...maybe....just maybe that could work.
Good idea maybe if i do it i can get vid.pics
Old Apr 7, 2006 | 07:33 PM
Tippyman's Avatar
Get a donut or shitty tire you don't care about and bounce it off the rev limit while doing a burnout. Either the engine will die from being bounced off the redline for so long, or the tire will burn down. Either way, it's alot of fun!
Old Apr 7, 2006 | 08:47 PM
Voodooboy520's Avatar
Pour BB's in the intake. It'll rattle real nice.
Old Apr 7, 2006 | 08:53 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: (Tippyman)
ideas on how to destroy a motor......ur an odd guy
i'd remove your revlimiter and get a 20K tach. see how high u can go b4 the rod goes though the piston LOL
get a welder accelletaline tank and or O2 tank and pipe that in the intake
Old Apr 7, 2006 | 09:56 PM
99teggsr's Avatar
Default Re: (DieMaster)
if you can get m-80s or equivelant, take the head off and put 4 of them in there on top of the pistons and bolt the head back on and run a long *** fuse and see if you can blow the head off.
Old Apr 7, 2006 | 09:59 PM
Maldito X's Avatar
Either way, this better be caught on film and posted, otherwise it will simply not be worth it at all.
Old Apr 7, 2006 | 10:51 PM
civiccoupe94's Avatar
put a P28 ecu in it and redline it doing burnouts?
Old Apr 7, 2006 | 11:47 PM
tek_civic's Avatar
ohhh,, PROPANE!! hook up a cheap bottle of propane($3.00 or so) with some braided line going into your cabin so you can turn it on/off in motion. get goin start a 3rd gear pull and hit it! haha.
that would be fun. i would say nitrous, but its a higher initial cost.
i LOVE the no redline and see how high we can go. if the engine itself limits it to a certain rpm(and lives) then go down hill and try it lol
GET IT ON VIDEO!! hah
Old Apr 8, 2006 | 08:21 AM
harmonator84's Avatar
Default Re: (tek_civic)
o you have to post pics of videos of this...this could be good.
Old Apr 8, 2006 | 08:51 AM
aXhatch's Avatar
Default Re: (harmonator84)
seeing as there is popular demand for a vid/pics of this i will be doign my best. unfortunately, my front clip is not here yet
Its still on the boat. literally. So maybe another 2 weeks this sucks cuz i dont ahve my car
Old Apr 8, 2006 | 08:55 AM
SHG_Beans's Avatar
replace the oil with dishsoap
Old Apr 9, 2006 | 01:56 AM
tek_civic's Avatar
maybe you could drain the oil, and instead of more oil, throw in some gas lol. there is a fire hazard here though.
can you borrow a nitrous kit from anyone?
if you can id say tear off the head, fill the water jacket with cement(home depot style), and hit it. your almost assured of getting a piston, or parts anyways, to go through the oil pan. heh
Old Apr 9, 2006 | 02:47 AM
ef92b's Avatar
Default Re: Stock Engine Destroyment? (aXhatch)
this is the real DIY thread, destroy-it-yourself , haha
Old Apr 9, 2006 | 07:37 PM
Maldito X's Avatar
put a CAI on it, take it to some dip on a road that's got lots of water, do a burn out on there, and watch the engine hydrolock...simple enough
Old Apr 9, 2006 | 07:45 PM
jpciii's Avatar
Pick a method that makes a lot of smoke. That would make for a better video.
Old Apr 9, 2006 | 07:53 PM
Bjorn20's Avatar
Default Re: (jpciii)
id almost say do the nitrous method, of running like a 100 shot on it, but thats probably too expensive and not even worth it to kill it.
um... rev the ****** to like 10k rpms, then while your going like 90 (no traffic...) put it in reverse and hit the gas. if that doesnt work, try draining the anti freeze and replace it with water (the passages in the engine are called water jackets ) then drain the oil. beat the **** out of the motor for like half an hour, if that, and it will die.
Old Apr 9, 2006 | 09:37 PM
tek_civic's Avatar
Default Re: (Bjorn20)
oh, just run the engine wot with the hood open, then put the intake pipe into a buket of water. just pull off the filter box. easy and fun.
Old Apr 9, 2006 | 09:43 PM
.God.'s Avatar
you guys suck, how could you intentionally kill an engine? Thats terrible. I mean maybe a lawnmower or something, but not a car engine, you gotta respect something that has served you well even if it is only a bunch of aluminum.
Maybe you should destroy yourself instead?
Old Apr 9, 2006 | 10:07 PM
jpciii's Avatar
Default Re: (..Lloyd Braun..)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aXhatch &raquo;</TD></TR><TR><TD CLASS="quote">
Its a crap motor. [...] with blown headgasket, piston/rings are fried, so its not worht trying to sell.
Old Apr 10, 2006 | 12:06 AM
tek_civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ..Lloyd Braun.. &raquo;</TD></TR><TR><TD CLASS="quote">you guys suck, how could you intentionally kill an engine? Thats terrible. I mean maybe a lawnmower or something, but not a car engine, you gotta respect something that has served you well even if it is only a bunch of aluminum.
Maybe you should destroy yourself instead?</TD></TR></TABLE>
rofl. thats funny. i could see "respecting" maybe if it gave you 200k good miles one one timing belt or something like that. but if he bought it, maybe put 5k miles or even 25k on it it has no sentimental value, or monitary value either, so boom! hahah
plus its entertainment for the rest of us. if one engine dies to entertain many people, then its a good death, especially when its not long for this earth as it sits.
on another note, i think my d15b might see a similar fate. gotta get some parts for my swap first though
Old Apr 10, 2006 | 12:16 AM
Ventolin's Avatar
Some dumbass guy bought a junker Civic 4 door for like $400 and wanted to know how he could make it really fast and go out and beat some kids at the street races. He honestly though his car was pretty quick and had VTEC and all this other ****..
So I told him about the "DIY" water cooling injection, and that he should run his windshield whiper fluid hoses into his intake and "spray" at WOT for a 20 hp increase. I havent heard from him so I doubt he really tried it.. but still, good idea..
Maybe you should try something like this... but possibly subsitute windshield whiper fluid for something flammable? Make sure you remove the catalytic convertor, maybe you can shoot some sweet flames.
Old Apr 10, 2006 | 12:17 AM
Ventolin's Avatar
Default Re: (Ventolin)
Fill your windshield whiper fluid reservoir with transmission fluid or seafoam, and then run the hoses into your intake. Then get on the freeway and smoke that **** up good on video!
Old Apr 10, 2006 | 09:50 PM
DieMaster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic &raquo;</TD></TR><TR><TD CLASS="quote">ohhh,, PROPANE!! hook up a cheap bottle of propane($3.00 or so) with some braided line going into your cabin so you can turn it on/off in motion. get goin start a 3rd gear pull and hit it! haha.
GET IT ON VIDEO!! hah</TD></TR></TABLE>
u cant use propane. it will stall the motor. up set the A/F ratio too much.
lol i like the cement idea thati'd be a new one in the crusher
try filling the block with C4 explosive! that will get the job done
GET THE VIDIEO OF IT!!!!!!
